September 04, 2026, 03:15:02 am
Hoffman Amps Forum image Author Topic: Marwi adapters  (Read 22025 times)
Marwi adapters
« on: October 19, 2021, 09:06:22 am »
I stopped making the Marwi adapters
These adapters let you mount the MS900 and MS1600 Chinese lights to the Marwi helmet and handlebar mounts
For those that have access to a 3D printer, I zipped up 3 STL files that you can use to make these mounts.
The .zip file is attached to this post
Here is the web store catalog page for Bike Light parts
https://hoffmanamps.com/MyStore/catalog/BikeLights.htm
Here is a link to the page that shows how these adapters are used
https://el34world.com/Misc/bike/BikesLights38.htm
« Last Edit: October 19, 2021, 09:10:02 am by EL34 »
Re: Marwi adapters
« Reply #1 on: October 19, 2021, 09:09:25 am »
Here is the info about the MS1600 adapter that I had on my web catalog page
MS 1600 adapter and screw
This adapter mounts to the bottom of a MS1600 style body.
It lets you use the Marwi helmet mount and New Style Handlebar mounts shown on this page.
The stock rubber band mounts found on Chinese lights are not very versatile, but the Marwi mounts are.
The adapter has a mounting hole for a screw that lets you bolt it to the bottom of the light
The power cord exits out the rear of the adapter
The adapter comes with a small 4mm button head mounting screw.
The adapter is shown in the picture on the left mounted to a light with a Marwi slide mount attached
You only get the adapter and screw, not the light or the Marwi slide mount
You will also need to order a Marwi Mount Kit shown on this page and a
Marwi Helmet mount or New Style Marwi Handlebar mount
« Last Edit: October 19, 2021, 09:13:00 am by EL34 »
Re: Marwi adapters
« Reply #2 on: October 19, 2021, 09:11:29 am »
Here is the info about the MS900 adapter that I had on my web catalog page
MS 900 adapter and screw
This adapter mounts to the bottom of a MS900 style body.
The groove in the adapter lets you bend the power cord to the left or right so it can exit to the side
« Last Edit: October 19, 2021, 09:13:32 am by EL34 »
