September 09, 2026, 09:29:43 am
Hoffman Amps Forum image Author Topic: 2204 add extra grid stoppers?  (Read 5514 times)
Offline joesatch
  • save me from myself.
« on: December 04, 2021, 10:28:04 am »
high gain build. what will adding extra grid stoppers do? Ex. add a 33k to V1b and V2a? I already have a 10k on V1a
Re: 2204 add extra grid stoppers?
« Reply #1 on: December 04, 2021, 12:33:40 pm »
They’ll act to limit the gain bandwidth product. Which may be useful, if the preamp is modded for higher gain, eg bypassed cathode/s.
Offline joesatch
« Reply #2 on: December 04, 2021, 01:17:44 pm »
Definitely i bypassed the cathode resistors with caps. The 10k stopper on V1 along with several 470p's in various places has quieted it down but i'd still like to tame it more without losing too much gain
« Reply #3 on: December 04, 2021, 01:40:30 pm »
In that case it’s worth doing, especially on the 3rd stage grid.
The downside of grid stoppers is the hiss they can add, but the further along the signal chain you go, it becomes much less of an issue (because the subsequent gain is much less).
Anode to cathode caps, 100 to 220pF mounted on the valve socket terminals, are also useful
« Last Edit: December 04, 2021, 01:45:54 pm by pdf64 »
Offline joesatch
« Reply #4 on: December 04, 2021, 02:08:10 pm »
i meant to ask about that. I currently have a 470p from the grid on V1a to ground. Will adding another cap across pins 1 & 3 do anything or interfere with the existing cap to ground from the grid (pin 2)?
« Reply #5 on: December 04, 2021, 02:56:19 pm »
Rather than interfere, additional filters will increase the high end roll off.
There’s various positive feedback loops that can form though, so rather than piling them on at the input stage, it may be better to spread them out.
So maybe add the anode to cathode cap on to the 2nd stage, and the grid stopper on the 3rd.
Offline joesatch
« Reply #6 on: December 04, 2021, 03:17:32 pm »
i like where you're going with this  :icon_biggrin:
