September 17, 2026, 10:36:53 am
Hoffman Amps Forum image Author Topic: Best method for 150v screen supply.  (Read 4067 times)
Offline Stuff4bikes
« on: January 02, 2022, 11:45:10 am »
Like the title states.....
I need 150v for the screens of two output tubes.
0A2 or dedicated seperate transformer?
Or if even possible another node on the PT dropping it down to the needed voltage.
Re: Best method for 150v screen supply.
« Reply #1 on: January 02, 2022, 11:51:40 am »
What is any available B+? How much current *and current swing* available/needed on main B+ and screen supply? Does your religion forbid Silicon?
What is "best"? Fastest? Cheapest? Coolest? Most stable? Best sound? Uses parts already in your shed?
Historically the answer was to use high-Mu(g2) tubes so that G2 could eat very nearly plates supply voltage, with maybe a slight filter between.
Offline Stuff4bikes
« Reply #2 on: January 02, 2022, 12:07:07 pm »
Sorry I am a novice hobbyist.
I have several nos 0A2 tubes and half a dozen 6BQ6gtb's just wanted to see if I can do something with them
Even if it was a ipod/CD/record player amp...
« Reply #3 on: January 02, 2022, 12:19:41 pm »
Connect a series resistor and 0A2 between B+ and ground. Take the 150V from the tube. Here's an example...
     https://el34world.com/charts/Schematics/files/Gibson/Gibson_mercury_i_ii.pdf
