September 16, 2026, 02:26:48 pm
Hoffman Amps Forum image Author Topic: DIY Princeton reverb won't develop negative bias voltage  (Read 5393 times)
Offline isaac_teller
« on: January 10, 2022, 10:32:00 am »
Hello. I have built a AA1164 exactly as per the schematic with the exception of a full wave bridge instead of a tube rectifier. All the voltages are where they should be except the bias voltage which jumps between 5-12 positive volts. I have tried both these bias circuits but neither one gives a steady negative DC voltage. What could be the problem? Thank you.
https://robrobinette.com/images/Guitar/Bassman/High_Voltage_Bias_Tap.pdf
https://el34world.com/charts/images/biascircuit2.gif
Re: DIY Princeton reverb won't develop negative bias voltage
« Reply #1 on: January 10, 2022, 10:41:18 am »
That bias circuit will not work with a FWB rectifier. See my Scrapbook pages 8 and 9 for the correct circuit to use.
« Reply #2 on: January 10, 2022, 10:46:33 am »
I'll try it(the one on the bottom left on page 8) and report back.
« Reply #3 on: January 10, 2022, 10:58:54 am »
Read page 9 if you haven't already
« Reply #4 on: January 10, 2022, 11:08:35 am »
Yes. Use the same values. The .047µF should be a Class X or Y cap, but you can use any .047µF @ 500V until you get a Class X.
« Reply #5 on: January 11, 2022, 04:26:28 am »
I hooked up the capacitive-coupled bias circuit and the amp works just fine now. Thank you Sluckey.
