September 17, 2026, 06:14:09 am
Hoffman Amps Forum image Author Topic: Filament fuse blows only when all tubes are installed  (Read 7551 times)
Offline Erik Aa
« on: February 19, 2022, 12:47:13 pm »
Hello. I have acquired a vintage EKO mod Evc 10 tube amp. It has two eec83 tubes and two el84 tubes. When I bring it up with my variac through a current limiter, the filament fuse (1a) blows. The fuse does not blow when I bring it up with the preamp tubes and one of the el84s. I can bring it up with either el84 tube, so it is likely not a bad tube. It is only when both el84s are in the amp that the fuse blows. Can anyone please help? Is the fuse wrong (1a glass wire fuse) or is it something else? Thanks!
Re: Filament fuse blows only when all tubes are installed
« Reply #1 on: February 19, 2022, 01:00:46 pm »
Wrong size fuse.
Each ECC83 filament draws .3A and each EL84 filament draws .76A. That's a total of 2.12A.
Offline Erik Aa
« Reply #2 on: February 19, 2022, 01:04:31 pm »
Thank you so much, Sluckey. What would you recommend? 2a slow fuse? Or something else? Thanks again.
Offline Latole
« Reply #3 on: February 19, 2022, 01:35:04 pm »
If tubes need 2.12 A a 2A fuse will blow
I'll put 3 A fast blow
Offline Erik Aa
« Reply #4 on: February 19, 2022, 02:07:57 pm »
Thank you Latole. I will try this then. Best regards.
Offline Latole
« Reply #5 on: February 19, 2022, 02:12:04 pm »
Do you have the schematic ?
I never saw a fuse on heater on old amps.
I never work on these Italian amp It is original ?
« Last Edit: February 19, 2022, 02:15:55 pm by Latole »
Offline Erik Aa
« Reply #6 on: February 19, 2022, 02:15:29 pm »
There is no schematic. I have vacuumed the internet for it. But I do have some pictures of the amp and the circuit.
Offline Latole
« Reply #7 on: February 19, 2022, 02:16:26 pm »
We like pictures !
« Reply #8 on: February 19, 2022, 02:30:18 pm »
I would use a 4A. Maybe even a 5A. If it was my amp I'd just put a jumper wire across the fuse holder.   :icon_biggrin:
« Reply #9 on: February 19, 2022, 02:34:06 pm »
Assuming UL rated fuse types, I suggest 3A antisurge / time delay / sloblo, as there will be an initial current surge at power up. Due to cold filaments having a lower resistance.
For IEC rated fuse types, T2.5A.
Offline Erik Aa
« Reply #10 on: February 19, 2022, 03:22:25 pm »
Here are some pictures of the amp.
Offline Erik Aa
« Reply #11 on: February 19, 2022, 03:23:18 pm »
One more picture.
Offline Erik Aa
« Reply #12 on: February 19, 2022, 03:32:29 pm »
Close up of circuit.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
https://soundcloud.com/ukiuki
Offline Erik Aa
« Reply #14 on: February 20, 2022, 11:17:10 am »
Thanks everybody for your inputs. Very helpful indeed. Regards.
