September 20, 2026, 12:54:40 pm
Hoffman Amps Forum image Author Topic: Power transformer "custom" wiring  (Read 3891 times)
Offline Marc
« on: March 17, 2022, 08:12:35 am »
Hello EL34 World Forum,
I built a working custom version of the Ampeg HB15.
https://ampeg.com/support/files/Schematics/H%20Series/HB-15%20(Heritage)/AMPEG%20HERITAGE%20B-15%202010%20SCHEMATIC%20AMENDED%202.7.2012.pdf
I have a question about the wiring of the power transformer,
on a 230VAC 50Hz electricity network (in fact it varies between 231 to 238 at least), is it safe to wire the Hammond 373BX in 240VAC mode?
  • 700VCT will be lowered which is what I want because B+ is around 480VDC and sometimes more
  • 6.3VCT will be in the tolerable range
  • 5VCT is not a problem (solid state rectifier is used)
Documentation:
To me it should be OK.
Are there any considerations / harmful things to take into account?
Re: Power transformer "custom" wiring
« Reply #1 on: March 17, 2022, 08:21:56 am »
Tollerance in the order of 15 - 20% (components & voltages) are acceptable in tube amps
Offline Marc
« Reply #2 on: March 23, 2022, 08:12:57 am »
Thanks for the advice.
I switched from 230 to 240VAC wiring mode and it works well.
The 6.3VCT is between 6.35 to 6.42VAC.
The B+ is now around 450VDC allowing me to use more 6L6GC models.
