September 16, 2026, 11:43:23 pm
Hoffman Amps Forum image Author Topic: Fender Deluxe Output Transformer testing  (Read 7736 times)
Offline fritz203
« on: March 20, 2022, 03:43:00 pm »
I tried to search for this topic, but couldn't find anything relevant.
Is there a way to test a Fender output transformer but just measuring the input/output winding ohms(not impedance)?
Offline Kaaskop
  • I Love Making Tube Amps
Re: Fender Deluxe Output Transformer testing
« Reply #1 on: March 30, 2022, 06:39:40 am »
Offline Latole
« Reply #2 on: March 30, 2022, 07:20:02 am »
No.
Only if windings read open you'll know it is bad.
Why do you want to test it ? What's wrong with the amp ?
« Last Edit: March 30, 2022, 07:23:25 am by Latole »
« Reply #3 on: March 30, 2022, 10:04:06 am »
you'll want a good meter that can "zero" out probe errors since some of the readings will be in sub-ohms
Offline fritz203
« Reply #4 on: March 30, 2022, 02:58:11 pm »
Ok, thanks for all your help, that is what I was looking for.
Offline Latole
« Reply #5 on: March 30, 2022, 03:06:47 pm »
Right DC resistors do not mean transformer will work / sound fine
« Last Edit: March 30, 2022, 03:16:25 pm by Latole »
Offline fritz203
« Reply #6 on: March 31, 2022, 10:16:22 am »
I figured out the transformer is fine, that was just a part of the troubleshooting. I had a screen resistor burn out and that took out the output tubes, so I wanted to check the transformer also. It turns out I had the output tubes biased too hot. All is fixed now. Thanks.
Offline Latole
« Reply #7 on: March 31, 2022, 10:24:38 am »
Good news !
What is the amp we are talking about ?
Offline Latole
« Reply #8 on: April 01, 2022, 05:25:59 am »
Useful ?
« Reply #9 on: April 01, 2022, 06:35:53 am »
A 'hard' fault on a push pull OT primary may be revealed by comparing the full primary resistance to the sum of the CT to anode resistances.
« Reply #10 on: April 01, 2022, 01:58:57 pm »
RG Keen has a transformer shorts tester.
« Last Edit: April 01, 2022, 03:03:41 pm by PRR »
Offline Latole
« Reply #11 on: April 01, 2022, 02:59:31 pm »
Him ?
R.G. Keen
Cheif Engineer
Visual Sound
www.visualsound.net
« Reply #12 on: April 01, 2022, 03:04:45 pm »
Yes but no. His personal site Geofex. http://www.geofex.com/  http://www.geofex.com/ampdbug/outtrans.htm
Offline Latole
Offline fritz203
« Reply #14 on: April 04, 2022, 03:40:11 pm »
Ok, thanks again.
