September 18, 2026, 07:31:21 pm
Hoffman Amps Forum image Author Topic: Add an effects loop to this Wurlitzer 700  (Read 4905 times)
Offline jewishjay
  • Merrily on my way to nowhere in particular!
    • my Reverb store
« on: April 24, 2022, 11:08:26 am »
Hey gang, I recapped this Wurli for a friend and now he'd like me to add an effect loop or at least a record out. Where and how would you do it? I'd really appreciate if someone could draw it clearly on this schematic. Thanks for everything!
Re: Add an effects loop to this Wurlitzer 700
« Reply #1 on: April 24, 2022, 11:21:00 am »
On this amp, you’d need another stage in front of the paraphase inverter for an FX loop methinks.
Although, if you only want a line out, you could put a voltage divider (with an output Jack) in parallel with the speaker(s) - across the secondary winding.
Offline jewishjay
    • my Reverb store
« Reply #2 on: April 24, 2022, 11:24:58 am »
Are you saying the "External Speaker" jack just needs a resistor or two to become a line out?
« Reply #3 on: April 24, 2022, 11:53:24 am »
2 resistors, but you only have a PA amp, NO pre-amp.  the pre amp would be the best for an FX, line out
Offline jewishjay
    • my Reverb store
« Reply #4 on: April 24, 2022, 03:26:08 pm »
The pickup goes into the "pre amp" the first triode, directly into the paraphase, to the 6V6s. Is there no good place to put a loop? Maybe off the volume control like robrob suggests here?....
https://robrobinette.com/Generic_Tube_Amp_Mods.htm#FX_Loop
