September 12, 2026, 07:15:00 am
Hoffman Amps Forum image Author Topic: separated speaker gasket  (Read 6214 times)
Offline PharmRock
« on: April 30, 2022, 05:17:55 pm »
I just traded for a Dr Z 2x12 open back cab with Celestion Blues.  Sounds great, no issues with the actual working part of the speakers.  I am in the process of cleaning up the cabinet and while removing the speakers, the cork gasket (I assume its cork) has separated (edit: I should point out that the gasket didn't separate in the process of me removing the speakers.  It clearly had already been in that state and there was no ripping/tearing when I removed them).  Think of a thick washer being cut on its edge into two thinner washers.  One half of the gasket almost appears glued/stuck to the baffle.  The other half is sitting exactly where it should be around the speaker cone.
So I figure I have two approaches...just re-mount the speakers and act like nothing has happened.  Or find a way to remove the "half-gasket" from the baffle in one piece and then reattach to the speaker.  Heat gun maybe?
If anyone has a solution I sure would appreciate hearing about it.
« Last Edit: April 30, 2022, 05:23:49 pm by PharmRock »
Offline thetragichero
Re: separated speaker gasket
« Reply #1 on: April 30, 2022, 09:46:49 pm »
sounds like it's a mount from behind cabinet so i would just match it up to where it came off and screw it back on
i only have experience with pressed paper gaskets (what sorta fancy pants speakers ya got in there using cork?) in which case wood glue and clamping generally works
Offline PharmRock
« Reply #2 on: May 01, 2022, 08:17:21 am »
After further inspection, its a pressed paper gasket.  When i get around to it, I'll try the heat gun approach and see if I can get the half-gasket off the speaker baffle without damaging it, then glue the gaskets back together as you suggested.  I went ahead and re-mounted to speakers and its good for now.  thanks!
