September 15, 2026, 03:14:13 am
Hoffman Amps Forum image Author Topic: Help wiring 2x12 cab  (Read 4651 times)
Offline joesatch
  • save me from myself.
« on: May 08, 2022, 07:08:40 pm »
Two 8 ohm greenbacks. I have a plate with two cliff jacks. I found this diagram on the interwebs which looks ok EXCEPT in 16 ohm mode the second speaker's negative has no path to the circuit (unless i'm conceptualizing the jacks in the wrong orientation). Can someone check this?
« Last Edit: May 08, 2022, 07:11:00 pm by joesatch »
Re: Help wiring 2x12 cab
« Reply #1 on: May 08, 2022, 08:24:25 pm »
The top speaker is hard wired to the 16Ω jack tip and sleeve. That's a deal breaker.
Offline joesatch
« Reply #2 on: May 08, 2022, 09:09:20 pm »
How would i take two cliff jacks and have one be 4ohm and the other be 16ohm?
History repeats itself
 :l2:
https://el34world.com/Forum/index.php?topic=24566.0
« Last Edit: May 08, 2022, 09:23:58 pm by joesatch »
« Reply #3 on: May 08, 2022, 09:20:35 pm »
Hurts my head to think about it. I'd do it like this...
Offline acheld
« Reply #4 on: May 08, 2022, 09:33:17 pm »
This schematic works with 3 jacks:  https://www.tubesandmore.com/sites/default/files/associated_files/s-h700_plug_drawing.pdf
I bought one these some years ago -- worked great until one of the jacks fell apart, and so I just rebuilt it with the schematic and parts I had laying' around.
Offline joesatch
« Reply #5 on: May 08, 2022, 09:40:24 pm »
i will try to work with this and eliminate the middle option. i believe this is what i need:
« Last Edit: May 08, 2022, 10:02:01 pm by joesatch »
Offline jordan86
« Reply #6 on: May 09, 2022, 07:33:28 am »
I’ve got one of these. It’s my second one technically. The first one failed on me for no reason. I add that only to say, their reliability is a bit suspect. Great concept though.
