September 15, 2026, 06:40:58 pm
Hoffman Amps Forum image Author Topic: Output transformer for PP EL 34  (Read 4878 times)
Offline Stuff4bikes
« on: May 11, 2022, 07:27:41 pm »
Will this work for JJ EL 34's in PP?
Offline dude
Re: Output transformer for PP EL 34
« Reply #1 on: May 11, 2022, 07:49:50 pm »
Yes
Offline Stuff4bikes
« Reply #2 on: May 11, 2022, 08:46:01 pm »
Thanks.....
Would just about any pp output transformer that was made for 6l6gc's work also....
Offline thetragichero
« Reply #3 on: May 11, 2022, 09:59:08 pm »
what are your plate and screen voltages?
Offline Stuff4bikes
« Reply #4 on: May 11, 2022, 11:25:11 pm »
Just ordered the EL 34's.....transformer is still in the box....nothing mocked up yet.....
What B+ should I be shooting for?
« Reply #5 on: May 12, 2022, 06:40:21 am »
guess it depends on what you're building? once you figure out what you want find a production model similar and 'borrow' from the prior art
folks smarter than i suggest designing the power supply first and then working backwards from the output to the input. unless I'm trying to use something I've already purchased (happens a lot as I'll salvage iron from various sources) i like to have a schematic sketched out before i even purchase anything
Offline Stuff4bikes
« Reply #6 on: May 12, 2022, 08:09:34 am »
Looks like a plexi 50 will be the next build.
I have said on here before I am just a hobbiest builder....I build amps somewhat like you guys breadboard. I don't play guitar well so i build an amp and let a friend play through it then we decide if it's something worth furthering. I just like tinkering with electronics. My friend is an accomplished guitarist and a "Marshall snob" so I like making him play through other designs.
Like many of you I have amassed  quite a bit of components for building and sometimes build and then just deconstruct it and use the iron for another project...and I haven't built anything with EL34's yet so I figured I would try..anyway thanks to all you guys and your help.
« Last Edit: May 12, 2022, 08:32:03 am by Stuff4bikes »
Offline Stuff4bikes
« Reply #7 on: May 15, 2022, 09:55:51 pm »
So I have 2,  360-0-360 transformers. I am thinking with SS rectification they should work for me.
I also have a 320-0-320 just incase.
