September 15, 2026, 06:45:20 pm
Hoffman Amps Forum image Author Topic: Super Champ XD Mod Sounds Great...then it doesn't  (Read 7546 times)
Offline JustMike
« on: May 26, 2022, 06:52:37 pm »
I found the DSP board bypass mod and did it to a dead amp. This little amp sounds really good! But after about 5 minutes of playing at full volume-which is a little loud for in the house, but probably not loud enough to play with a rock drummer- it gets a little distorted and the volume fades to less than half. I don't see any red plating and if I turn it off for only a couple of seconds and back on, it plays at full volume. :dontknow:  Any ideas what could be causing this?
I'm learning...
Re: Super Champ XD Mod Sounds Great...then it doesn't
« Reply #1 on: May 27, 2022, 05:04:42 am »
When I have had that happen it has been an oscillation issue. It was resolved with new power tubes.
Offline JustMike
« Reply #2 on: May 27, 2022, 04:19:09 pm »
Hmm...I have new JJ6v6's in it. Grid stoppers?
I'm learning...
« Reply #3 on: May 27, 2022, 05:23:00 pm »
Not saying power tubes are the issue in your case.  It could certainly be something else.
I will say the first time I had oscillation problems were with brand new EL84 tubes right after I installed them.   :dontknow:
Offline JustMike
« Reply #4 on: May 27, 2022, 05:52:01 pm »
 Could it have anything to do with the 5u tone cap? I didn't have a regular one, so I used an electrolytic. Tied the - to gnd.
I'm learning...
« Reply #5 on: May 27, 2022, 08:44:21 pm »
Maybe heat-related part failure
Offline glass54
« Reply #6 on: May 27, 2022, 09:05:35 pm »
Mike
What is the DSP bypass mod that you invoked. I could think of one BUT what did you do?
It might help us narrow down the culprit  :laugh:
There is a Mute circuit (Q3) between 2 Op Amps which may be contributing to your worries??
Regards
Mirek
"To measure is to know"
Offline JustMike
« Reply #7 on: May 28, 2022, 06:14:45 am »
 I think it's been discussed here before.
I'm learning...
Offline JustMike
« Reply #8 on: May 28, 2022, 10:37:57 am »
I have it on the bench and Im monitoring plate voltage. Pretty steady at 377v. When I touch just the tip of the input cable, The plate voltage drops to 317. This happens only when Im not grounded and the amp squeals. Is this normal? When im grounded (touching both tip & sleeve of guitar cable, plate voltage is steady).
I'm learning...
Offline JustMike
« Reply #9 on: May 30, 2022, 08:05:20 am »
 So this probably isn't the most efficient way to troubleshoot, but I put in a power amp input jack. I've been running an external preamp into it and it's not acting up. So this points to the op amp preamp stage. I guess I could get the old can of freon and start spraying components. A friend who I do repairs for has offered me a scope for my services. He has no idea what model it is, but we'll see.
I'm learning...
Offline glass54
« Reply #10 on: May 30, 2022, 07:25:26 pm »
I think you have done good  :laugh:
That's probably the way I'd attack the situation, test and prove the PA is all well.
Then....
Regards
Mirek
