September 19, 2026, 12:10:34 am
Hoffman Amps Forum image Author Topic: Vibrato sound on a non-vibrato amp?  (Read 7563 times)
Offline DuaneOh
  • Tube Amp Apprentice
« on: June 24, 2022, 06:41:10 pm »
I have a '59 Fender Harvard 5F10 that is mostly original and am getting a faint fast vibrato, mostly noticeable when playing higher single notes, especially on humbucker equipped guitars. I haven't opened it up yet to look inside, I was hoping to get some direction before I go in. Any suggestions on where to look?  Thanks.
Re: Vibrato sound on a non-vibrato amp?
« Reply #1 on: June 24, 2022, 06:58:27 pm »
Got a fan in the room?
Offline DuaneOh
« Reply #2 on: June 24, 2022, 07:21:57 pm »
You are a genius! Turned off the fan and the vibrato went away. Thanks!
Offline brewdude
« Reply #3 on: June 25, 2022, 01:15:24 am »
That is soooo funny!
I was once pulling my hair out trying to find an oscillation.  It took two days to figure out it was the ceiling fan above the table I was working on.
Offline zircontweezer
« Reply #4 on: June 25, 2022, 04:51:51 am »
So just to clarify it's a mechanical/audio effect of the fan blades rotating that makes the vibrato and not electrical interference? Just asking as I've never heard of that problem before but it is summer in the northern hemisphere so I guess the fans are back in use.
« Reply #5 on: June 25, 2022, 06:40:46 am »
yes mechanical, mine sounds like a chevy 350 outside idling, been to the window 12 times no Chevy!  :icon_biggrin:
« Reply #6 on: June 25, 2022, 02:12:15 pm »
Big blades are acoustic reflectors. Sometimes they reflect to your ear, sometimes away from your ear. Ceiling fan speed is right in the tremolo register.
« Reply #7 on: June 26, 2022, 10:28:12 am »
And we spent time and $ to modify our amp's if they didn't have the feature  :l2: :l2: :l2:
Offline Greg
« Reply #8 on: June 26, 2022, 11:21:48 am »
Luckily, this amp didn't have a built-in tremolo circuit. It is not hard to imagine somebody like myself butchering an amp only to discover the fan problem after a 3-pages-long troubleshooting thread.
Offline brewdude
« Reply #9 on: June 26, 2022, 05:20:20 pm »
The other frustratingly simple noise rabbit hole I was almost sucked into…
A rattling sound that turned out to be a bowl of loose change.
« Reply #10 on: June 26, 2022, 05:34:45 pm »
I went through similar situation,, strange metallic rattling, spent a good amount of time trying to find something wrong with the amp, then the cab only to find it was pots and pans vibrating in the pantry..
Offline brewdude
« Reply #11 on: June 26, 2022, 06:51:11 pm »
Snare drum?
Offline Lectroid
« Reply #12 on: June 28, 2022, 09:19:20 am »
Another:  I spent hours tracing down why my scope showed such dirty spikes and trash on a freak generator signal.  Then I discovered it was the power supply for the LEDs around my magnifying lens...
Magis bos clocca!
Free Beer Tomorrow!
