August 07, 2026, 12:20:58 am
Hoffman Amps Forum image Author Topic: 6JB6A in a guitar amp  (Read 5870 times)
Offline Hojvaelde
« on: June 26, 2022, 03:49:18 pm »
Hi everyone here.
After being away from my tube hobby for a few years, now I am back again.
I ran across a bunch of 6JB6A. Some used, some new.
I would like to work a little with these tubes.
Has anyone used them (or similar) in a guitar amp?
Re: 6JB6A in a guitar amp
« Reply #1 on: June 26, 2022, 11:00:09 pm »
Hi everyone here.
Never used 'em. But your first stop  for the design centre values you'll need is the data sheet. https://frank.pocnet.net/sheets/049/6/6JB6A.pdf
« Reply #2 on: June 27, 2022, 05:08:16 am »
it's early and my coffee is HOT, but a snivet?
best I can do is Silly Naval Intelligent - VET :icon_biggrin:
« Last Edit: June 27, 2022, 05:39:50 am by tubeswell »
« Reply #4 on: June 27, 2022, 06:03:59 am »
I wonder how it can be described as a beam power tube, yet have a 3rd grid (ie rather than beam forming plates)?
Offline Williamblake
« Reply #5 on: June 27, 2022, 07:42:52 am »
If colour accuracy is not a concern maybe built a tv? Seriously, get some tubes with a known schematic.
« Reply #6 on: July 02, 2022, 11:49:00 pm »
Cousin to the 6JM6A & 6JN6 (Compactron versions w/o and w/ plate cap)  - Pete Millette built what he called the "Engineer's Amp" - Data on that project here. Full schema here. Copy the output stage and the power supply - Iron is available from Edcor, find that information here.
Basically, 325V B+ with an 8Ka-a reflected load. The power transformer has dual 50V taps that allow use of a FW bias supply, as it's a bit more reliable/safe than the conventional 1/2 wave plans we usually find.
Couple to an AB763 Deluxe or Bassman AA864 or AB165 preamp with the phase inverter, alternatively, if like British tone, couple with the Marshall JBM 800 preamp and phase inverter. If you want to really get extravagant, couple to a Dumble-ish preamp or Soldano SLO preamp.
I have built guitar amps with 7867/6CD6GA and 6JB5/6HE5 with success, ping us if you care to have the schematics/docs to either of those. I took the simplistic path for preamps - 5E3-ish and Matchless Lightning types.
--Pete
« Reply #7 on: August 19, 2022, 04:03:55 pm »
