September 19, 2026, 02:19:24 am
Hoffman Amps Forum image Author Topic: Sluckey matchless board  (Read 4899 times)
Offline ok_state_blues
« on: June 27, 2022, 05:55:55 am »
I am making good progress on populating the board but am having a small issue. I do not want pre amp in/power amp out. Those resistors on the jacks/pots are removed and only the ones on the board remain correct? Also where should the power amp input be connected? Any help is greatly appreciated.
Offline Williamblake
Re: Sluckey matchless board
« Reply #1 on: June 27, 2022, 07:27:34 am »
If you dont want preamp in power amp out you can skip all of it.
« Reply #2 on: June 27, 2022, 07:45:45 am »
Remove the green wire that went from the power amp input jack to the board.
« Reply #3 on: June 27, 2022, 10:09:53 am »
Ok thank you for the reassurance. I felt like I was getting lost in the details and overthinking your note in the build document.
« Reply #4 on: July 10, 2022, 05:03:30 pm »
As a promise to Sluckey, Hammond AO-14 chassis to Matchless lightning.
