September 19, 2026, 01:58:17 pm
Hoffman Amps Forum image Author Topic: diodes/rectifier switch  (Read 6477 times)
Offline isaac_teller
« on: July 07, 2022, 07:29:36 am »
Hello. I'm building a AA1164 Princeton and the user wants the option of switching from diodes to rectifier tube. Unfortunately he informed me of this after I had already installed a non center-tapped power transformer. I drew up a possible solution. Does anyone see a problem with this?
Offline jordan86
Re: diodes/rectifier switch
« Reply #1 on: July 07, 2022, 07:47:26 am »
I don’t know enough to say how a non center tapped PT would affect this, but I’d tell that fella you snooze you lose, and then have him buy one of these  :laugh:
https://tubedepot.com/products/solid-state-rectifier?utm_source=google&utm_medium=cpc&adpos=&scid=scplpSSR&sc_intid=SSR&gclid=EAIaIQobChMIwLWHlefm-AIVMhXUAR0l9gwXEAQYAiABEgJiUvD_BwE
« Reply #2 on: July 07, 2022, 08:03:27 am »
I thought of doing that but if the above solution is feasible it's not that much of an effort to add one switch and 4 diodes.
Offline joesatch
  • save me from myself.
« Reply #3 on: July 07, 2022, 08:16:36 am »
switchable rectifier sounds good on paper. i think it's alotta work for little reward. you have to have some resistor switching in it to get the same bias because that will be off (orr you have to find a bias middle ground). Also, could be bad for the filter caps going from gradual current to rushes of current?
« Reply #4 on: July 07, 2022, 08:24:07 am »
Is your build a SS recto? I'm just curious as to why you would build an AA1164 PR with a non center-tapped PT?
« Reply #5 on: July 07, 2022, 08:30:59 am »
Works on paper. How will you connect the bias supply? Can we see a complete schematic for your non-standard PR?
« Reply #6 on: July 07, 2022, 08:45:50 am »
The original requirement was for a full wave bridge only. This is the current bias supply. Other than full wave bridge, standard AA1164.
https://robrobinette.com/images/Guitar/Bassman/High_Voltage_Bias_Tap_Bridge_Rectifier.png
« Reply #7 on: July 07, 2022, 12:00:47 pm »
Yes, See hybrid bridge rectifier in this link http://www.valvewizard.co.uk/bridge.html
(You also need a filament winding for the tube)
« Last Edit: July 07, 2022, 12:18:05 pm by tubeswell »
« Reply #8 on: July 07, 2022, 12:32:40 pm »
I have a small 5 volt, 3 amp filament transformer that I added to the chassis.
