September 20, 2026, 05:11:22 pm
Hoffman Amps Forum image Author Topic: Simplify or remove tonestack?  (Read 5524 times)
Offline joesatch
  • save me from myself.
« on: July 14, 2022, 10:03:08 am »
i blast you folks with questions . I have multiple projects going.  I would like to simplify this tonestack to just a Tone pot or remove it all together. I still would like to keep the master vol in place.
« Last Edit: July 14, 2022, 10:16:00 am by joesatch »
Re: Simplify or remove tonestack?
« Reply #1 on: July 14, 2022, 10:33:04 am »
Offline joesatch
« Reply #2 on: July 14, 2022, 10:56:04 am »
Outstanding. i see. come off v1a pin 1 with a 22nf cap into the master with a 220pf cap over the master in/out lugs
« Last Edit: July 14, 2022, 10:58:31 am by joesatch »
Offline SILVERGUN
« Reply #3 on: July 14, 2022, 11:45:36 am »
I did something similar and had these results:
The "tame" mid-scooped clean channel turned into a mid-heavy crunch channel. The only clean-cleans existed at the very low end of the volume pot.
That tone stack is pretty lossy so if you completely remove it there will be much more gain available at the volume pot to feed the next stage.
Positive or negative is up to your taste.
Offline joesatch
« Reply #4 on: July 14, 2022, 01:45:06 pm »
Thanks for the heads up, i will retain the TS in the schematic
« Reply #5 on: July 18, 2022, 05:55:42 am »
You don't specify the reason by which you want to semplify or remove the TS
as your decision wast to retain it, may be you can be interested in a RAW control
Connect a pot as rehostat and put it between the TS and ground, this has the effect to control the effect of the TS on the circuit
Offline jordan86
« Reply #6 on: July 22, 2022, 09:22:11 am »
A raw control is great on a blackface type TS. I have one on my Princeton. What you are essentially doing is adding to the value of that mid resistor, which minimizes the effect of the tonestack. Most blackface amps have something under 10K for the mid resistor value. As you get that closer to 25K-50k things feel much more tweedy. Over about 100k the tonestack is not much more responsive, mostly defeated. After that, it’s just more gain.
If you go here and adjust the value of RM (mid residtor), you can see what it does to gain and frequencies. I made a graph of this once at several snapshots but can’t find it.
https://www.guitarscience.net/tsc/fender.htm#RIN=38k&R1=100k&RT=250k&RB=250k&RM=10k&RL=1M&C1=250p&C2=100n&C3=47n&RB_pot=LogA&RM_pot=Linear&RT_pot=LogA
« Last Edit: July 22, 2022, 09:28:23 am by jordan86 »
Offline jordan86
« Reply #7 on: July 22, 2022, 09:26:41 am »
Here is my graph.  Also an image of how guys usually implement it. The normal mid resistor (6.8K or 10K) comes off the raw pot to ground.
