September 19, 2026, 11:11:23 pm
Hoffman Amps Forum image Author Topic: B+ fuse  (Read 5358 times)
Offline joesatch
  • save me from myself.
B+ fuse
« on: July 24, 2022, 02:08:39 pm »
Where would i put the B+ fuse in this layout?  Also what is the 150k resistor to ground doing?
« Last Edit: July 24, 2022, 02:11:06 pm by joesatch »
Offline trobbins
    • Tim's projects and info
Re: B+ fuse
« Reply #1 on: July 24, 2022, 06:26:03 pm »
Imho, the fuse should go in one of the transformer winding arms.  The fuse type and rating can be determined by either testing, or design.
The use of a zener in each winding arm is a concern.  In general, the zener needs to have a lot of design margin with respect to peak current/dissipation and to conductive cooling.  One could presume that the zeners are included to fit better with the output stage valves, but it could also be to include a voltage margin on the first filter capacitor - that all gets a bit dicey depending on mains voltage variation, and the exact power transformer being used.
It sounds like you may be trying to clone someone else's schematic - which is fraught with risk unless you intimately know all the parts being used and the application and measurements that have been made.
Offline joesatch
Re: B+ fuse
« Reply #2 on: July 24, 2022, 07:28:22 pm »
- i didnt intend to use those extra 2 diodes.
- what is the 150k doing?
- i understand the risks and have decided to proceed with caution
Offline thetragichero
Re: B+ fuse
« Reply #3 on: July 24, 2022, 08:08:43 pm »
150k resistor is to bleed the filter caps after power is switched off. i usually don't go this low in value
Offline dude
Re: B+ fuse
« Reply #4 on: July 24, 2022, 08:58:47 pm »
Use 220k bleeding R, 3 watt
Offline dude
Re: B+ fuse
« Reply #5 on: July 24, 2022, 10:30:19 pm »
Some Marshall’s put the 1/2 amp slow blow fuse right after the the rectifier; before the fist filter.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: B+ fuse
« Reply #6 on: July 25, 2022, 10:37:30 am »
Always a reference to look at >>>
http://www.valvewizard.co.uk/fuses.html
https://soundcloud.com/ukiuki
Re: B+ fuse
« Reply #7 on: July 25, 2022, 12:48:23 pm »
