August 05, 2026, 07:57:39 am
Hoffman Amps Forum image Author Topic: Switched Input with relay.  (Read 5492 times)
Offline joesatch
  • save me from myself.
« on: August 01, 2022, 09:28:30 am »
Switching input between two separate grids (and preamp circuits) . See if this looks right.  Since the triode needs to have a continuous grid leak, when switched on it will see close to the 1M (2.2M + 2.2M parallel). When disengaged the triode still has a grid leak of 2.2M.  Is this the preferred way?
« Last Edit: August 01, 2022, 10:08:12 am by joesatch »
Re: Switched Input with relay.
« Reply #1 on: August 01, 2022, 10:33:45 am »
No. We already discussed this. You need to ground the unused grid.
Offline joesatch
« Reply #2 on: August 01, 2022, 11:13:23 am »
the triode will die of there is no grid leak?
Your're proposing this?
« Last Edit: August 01, 2022, 11:31:15 am by joesatch »
« Reply #3 on: August 01, 2022, 11:31:55 am »
here's something from the ValveWizard;
my take from reading;
If there is zero volts at the grid, regardless the bias, there is no current
Offline joesatch
« Reply #4 on: August 01, 2022, 11:36:51 am »
my inital diagram kept a grid leak in place (valve biased). With grid to ground is the valve not biased?
« Reply #5 on: August 01, 2022, 11:52:00 am »
Of course the tube will still be biased properly. But 1M is the more common value. Rarely will you see 2.2M.
But, grounding the unused grid has nothing to do with proper bias. It has everything to do with reducing amp noise. If you only have a big resistor on the grid, all kinds of noise can come into the amp via the high impedance grid circuit. But if you ground that grid when it's not in use all that noise will be killed and the amp will not just sit there buzzing like an angry bee hive. This is the same reason you see switching jacks used for input jacks. The switching jacks keep the unused grid quiet when not in use.
If you still don't believe me just build it your way and see. Then you can add the ground switching to fix it.   :l2:
Offline joesatch
« Reply #6 on: August 01, 2022, 12:17:05 pm »
Thanks for your input Sluckey, i dont doubt your expertise, that is why i come here. I have left a piece of information out. I am grounding the signal path further down the chain with another relay. With this in mind, what is the affect on the triode having a 2.2M in place vs ground when unused?  I will try your way (my second diagram)
« Last Edit: August 01, 2022, 12:21:57 pm by joesatch »
Offline joesatch
« Reply #7 on: August 01, 2022, 12:26:27 pm »
I have taken these two channels from two different multichannel circuits. I was going to ground them where they initially were grounded to mute the channel  (X88 lead channed and HBE channel). I have circled the spots.  i will try your way, if it works well i have an extra relay i can use for something else. Also how does the output stage look (both channel MV feeding the grid)
« Last Edit: August 01, 2022, 12:55:08 pm by joesatch »
« Reply #8 on: August 01, 2022, 01:14:17 pm »
Not good. Turning either MV to zero will totally kill the other channel.
Offline joesatch
« Reply #9 on: August 01, 2022, 01:29:32 pm »
Youre right i forgot those needed to be switched as well. so i guess that's where my second relay will go. X88 has each MV switched in or out with an optocoupler
« Last Edit: August 01, 2022, 01:32:34 pm by joesatch »
Offline joesatch
« Reply #10 on: August 02, 2022, 11:32:13 am »
Ground the grid before the grid stopper resistor or after?  Does it matter?
Offline Williamblake
« Reply #11 on: August 02, 2022, 04:00:35 pm »
Dont know if it matters, but there will be a difference. One way it is a voltage divider and the other way it is not. Also i would want to be the grid stopper directly at the grid but not the grid leak as it gets messy quickly.
