August 05, 2026, 10:49:25 am
Hoffman Amps Forum image Author Topic: stronger reverb needed in a TK Imperial circuit  (Read 3749 times)
Offline Bieworm
  • I like it loud!
« on: August 04, 2022, 02:55:16 am »
Hey guys.. maybe you can look at this schematic and give some advice on making the reverb stronger in a TK Imperial circuit.
It looks like it has the same tube layout as the blackface reverb but the components differ. I already tried a larger cathode bypass cap on the 12AT7 driver side. (22uf vs 4.7uf) But that doesn't do much IMHO
Maybe a higher value reverb level pot?
And what is the benefit of that 200R (R33) resistor after the cathode bypass cap (C23)?
muchos thanxos
Re: stronger reverb needed in a TK Imperial circuit
« Reply #1 on: August 04, 2022, 05:42:11 am »
These changes should get you a lot more reverb...
Offline Bieworm
  • I like it loud!
« Reply #2 on: August 04, 2022, 05:48:44 am »
Steve, you're the best!👍thanks!!!
