August 05, 2026, 10:21:56 pm
Hoffman Amps Forum image Author Topic: New 18 Watt Build  (Read 3609 times)
Offline zendragon63
  • Vacuum Packed Tone
New 18 Watt Build
« on: August 08, 2022, 10:25:19 pm »
Hey gang, Haven’ t built anything for a while—though I still lurk here regularly. Here is a recently finished modified 18 watt with a EF86 and TMB. Liberties taken nonetheless…
Started with a handful of leftover parts. I didn’t know whether I would like the EL84s but I was surprised on the volume and tones that I am finding.
This is a scaled version of the Trojan Horse amp I built and sold several years ago. The LND150 stage was put in the front of the EF86 to drive it and get a little more harmonic content out of it but mostly to flip the phase to match up with the Marshall side. I had hoped to have a little more preamp voltage to work with—so after calculating plate and screen current possibilities ad nauseum, I ended up setting the Kbias, Rg and Rp close to Vox values and to suit a Stratocaster. The EF86 was shock mounted using a couple of left-over reverb tank silicon washers.
The result is that is sounds outstanding in a 2x12 Bluesbreaker combo cab. EF86 and single coils are a great match IMHO.
Building each of these amps always turns out to be an adventure; start with a blank chassis and then make a lot of it up as I go along (all by trying to avoid some if the mistakes of the last amp). I appreciate Doug and all of you for the knowledge and skill we are able to share on this forum.  Regards
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
Re: New 18 Watt Build
« Reply #1 on: August 09, 2022, 05:10:03 am »
That's super cool!  Thanks for sharing this. I always admire your ingenuity with your amp designs.  Well done!
