August 06, 2026, 05:33:01 am
Hoffman Amps Forum image Author Topic: Dual PPIMV? Anyone?  (Read 3709 times)
Offline Ledvedder
Dual PPIMV? Anyone?
« on: August 11, 2022, 12:03:43 pm »
Has anyone done this to a 1987/1959 circuit? If so, I'm wondering how it works, and hopefully get more information about it. I have a PPIMV in my 1987 build that works pretty well, but I'd love to have dual switchable ones.
http://forum.metropoulos.net/viewtopic.php?t=45431
Re: Dual PPIMV? Anyone?
« Reply #1 on: August 11, 2022, 05:04:55 pm »
Never tried
But I don't see a reason to don't give a try
you can do all trying without mod to the faceplate and using a DPDT Switch
Then, if you are satisfied you can go on with the necessary faceplate mod
Our friend Da Geezer experimented something like that in one amp (don't remember which kind of amp)
p.s.: May be a relay and the use of a FS will result more performant instead of a panel switch
« Last Edit: August 11, 2022, 05:13:03 pm by kagliostro »
Offline acheld
« Reply #2 on: August 11, 2022, 06:18:31 pm »
This may or may not be relevant, but Dumble included a "trim" pot for the LTP in the #124 and others -- this varied the plate resistance in lieu of the usual Fender 82K/100K.  One had to adjust the the trim pot to the "optimal" tone using an arcane (to me) method.  Wouldn't a dual PPIMV do the same?
