August 07, 2026, 10:00:19 am
Hoffman Amps Forum image Author Topic: Size Of Wire Used In Power & Output Transformers  (Read 4067 times)
Offline Pollys13a
  • Rock n Roll Tunes For Grown Up Goons.
« on: August 19, 2022, 03:56:22 am »
Hi,
What size or sizes of wire would be used in making power and output transformers?
Thanks.
Re: Size Of Wire Used In Power & Output Transformers
« Reply #1 on: August 19, 2022, 04:07:20 am »
This question don't has a response
Many thikness are used and, also, to solve technical problems, paralleled double or triple wires can be used instead of a single ticker wire (that is an optimisation of the spaces between wire and wire on the winding) to be able to fit the winding in the available space that depends on core size, about core there are standards indicated, as an example, with E32 core, and this, yes, semplify life
« Last Edit: August 19, 2022, 04:13:56 am by kagliostro »
Offline Pollys13a
« Reply #2 on: August 19, 2022, 02:56:48 pm »
OK.Thanks.
Offline nandrewjackson
« Reply #3 on: August 19, 2022, 06:05:25 pm »
Good question.
I remember seeing an 18(22)Watt PT that had the tiniest little hair sized wire coming up to the terminals (Chinese made amp).
Offline acatlow@gmail.com
« Reply #4 on: August 23, 2022, 12:59:36 am »
depends... on what you are winding the transformer for
