August 07, 2026, 04:16:36 am
Hoffman Amps Forum image Author Topic: 3 button footswitch with a TRS ?  (Read 5625 times)
Offline joesatch
  • save me from myself.
« on: August 19, 2022, 01:33:56 pm »
Is this possible?  I have 3 relays in the amp each activates with a ground.  Theoretically a TRS can have 3 combinations. How?
Tip-Ring
Tip-Sleeve
Ring-Sleeve
Re: 3 button footswitch with a TRS ?
« Reply #1 on: August 19, 2022, 02:01:46 pm »
not possible
« Reply #2 on: August 19, 2022, 02:55:38 pm »
Have you seen TRRS?
I have only seen them in 1/8", but that should do it.
« Reply #3 on: August 19, 2022, 04:34:13 pm »
Tip-Ring
Tip-Sleeve
Ring-Sleeve
If you connect T and R, and T and S, then you already have an R and S connection.
So there's no 3rd state.
Offline thetragichero
« Reply #5 on: August 19, 2022, 05:20:38 pm »
so it is *possible* (check out the fender m-80 chorus or fender Princeton chorus) but requires a bunch of additional circuitry
for diy a 5-pin din connector is your friend
Offline nandrewjackson
« Reply #6 on: August 19, 2022, 05:52:31 pm »
The fender red knob twin uses a T/S for 2 switching operations. It feeds an AC signal and each footswitch has a series diode, so only either the positive side or the negative side is activated.
Your solution may be in that logic somehow.
I can't remember the internal switching circuit, but I know that's how the footswitch works on that one.
That schematic may also be difficult to find a nice clear legible version.
« Reply #7 on: August 19, 2022, 05:57:38 pm »
+1 for a DIN (midi) cable for footswitch. The sockets and cable are just as easy to purchase as 1/4" equipment
Offline joesatch
« Reply #8 on: August 19, 2022, 10:36:55 pm »
is possible with some extra parts inside the amp. i will figure this out.
Offline acheld
« Reply #9 on: August 20, 2022, 10:21:00 am »
I've had good luck with DIN connectors and multi conductor cables designed for this.  I like relays, though they certainly do increase the complexity of a build.
Take care that your connectors -- panel and cable -- are in fact compatible.
Newark has a great selection, PartsExpress as well.
Offline Williamblake
« Reply #10 on: August 20, 2022, 05:16:40 pm »
Why not use some diodes for making four circuits out of two?
