August 09, 2026, 05:17:49 pm
Hoffman Amps Forum image Author Topic: Solid state CF harmonic trem  (Read 8008 times)
Offline Esquirefreak
« on: August 21, 2022, 05:43:21 am »
If one used a solid state cathode follower, one could build a single channel revision-A brownface amp with only 4 tubes.
The CF part was posted by Tubenit in this thread: https://el34world.com/Forum/index.php?topic=23811.0
I'm trying to fit all the pieces together, does this look about right to those with knowledge?
Re: Solid state CF harmonic trem
« Reply #1 on: August 21, 2022, 06:27:17 am »
Yes, you can use an N-channel MOSFET (like an IRF820, which, in the TO-220 package, is rated for 500V and 1A without a heatsink) as a Source Follower in place of where you might otherwise use a CF as an impedance buffer/current driver - and you don’t need to worry about heaters (or H-K insulation). And an IRF820 will just sub straight in place of a 12AX7 triode with no other circuit modifications needed, bar one -Good practice to use a 12v Zener between the Gate and the Source.
« Last Edit: August 21, 2022, 06:30:30 am by tubeswell »
« Reply #2 on: August 21, 2022, 06:57:33 am »
INT pot is wrong. Phase splitter has grid connected to cathode. Modulator lower tube grid has no ground reference resistor.
« Reply #3 on: August 21, 2022, 07:28:43 am »
Ah! I missed the 1M resistor from the original schema. Would please correct my wiring of the INT pot? Thanks a bunch for helping out.
/Max
« Reply #4 on: August 21, 2022, 08:10:57 am »
« Reply #5 on: August 21, 2022, 08:42:47 am »
A thousand thanks, Sir  :icon_biggrin:
/Max
« Reply #6 on: August 21, 2022, 08:55:48 am »
Are the gate and source internally connected or do I need to bridge them? (I have VERY little experience from messing with transistors, let alone Mosfets.
/Max
Offline dwinstonwood
« Reply #7 on: August 21, 2022, 09:43:15 am »
...I have VERY little experience from messing with transistors, let alone Mosfets.
/Max
First, thanks Esquirefreak for posting about this. It's a cool idea that eliminates an extra tube and socket from the chassis.
I also have practically no experience with solid state parts, and I can't really read their schematic symbols. The thing I've circled confuses me. Does that mean no connection is made at that point?
Thanks!
« Reply #8 on: August 21, 2022, 10:15:19 am »
That is just an arrow that indicates N-channel or P-channel. It is not a connection. There are only three leads on an IRF820.
« Reply #9 on: August 21, 2022, 10:17:36 am »
DO NOT CONNECT THE GATE TO THE SOURCE! Simply connect the three leads of the device exactly as shown.
« Reply #10 on: August 21, 2022, 10:49:57 am »
Now I see the middle/gate connection. I didn't get it at first. Zener between the gate/source as stated above.
Thanks!
/Max
« Reply #11 on: August 21, 2022, 12:50:35 pm »
Thanks sluckey. Another reading list to compile...
« Reply #12 on: August 31, 2022, 06:02:26 pm »
It'll be a while until I get to work on this build, due to economics and so on. I have made and populated the boards. Will keep you updated when there's progress made.
However, I bought some IRF820 transistors and 12V Zeners, and figured that, while playing the waiting game, I might try the CF network on my center volume based (6G4) build.
Does this look right?
« Reply #13 on: August 31, 2022, 07:23:59 pm »
no
« Reply #14 on: August 31, 2022, 07:37:15 pm »
That bad, huh? Hmm, back to research, I guess  :laugh:
/Max
« Reply #15 on: August 31, 2022, 07:54:42 pm »
Didn't like my simple drawing?
« Reply #16 on: August 31, 2022, 08:09:14 pm »
Yeah, of course I did! But I tried to adapt your drawing to a 6G4 rather than the -A revision, since the phase inverter stage and filter is different. As that amp is already built I'm trying to change as few parts as possible. I just don't understand how and where the CF is incorporated  :think1:
I'm using your drawing for my next build. Since I'm using that circuit from scratch I made the board accordingly.
« Reply #17 on: August 31, 2022, 08:29:37 pm »
Aha, the Zener is in the wrong place, right?
« Reply #18 on: August 31, 2022, 08:34:18 pm »
The whole point of this thread was to replace the CF in a 6G4-A trem circuit so you could use only 4 triodes. We did that.
Now you're trying to put a CF in the totally different 6G4 circuit. Guess what. Ain't no CF in the 6G4 circuit!
« Reply #19 on: August 31, 2022, 08:45:27 pm »
Point taken, I won't go off topic.
/Max
