August 07, 2026, 08:22:02 am
Hoffman Amps Forum image Author Topic: Sunn Grid Noise  (Read 5381 times)
Sunn Grid Noise
« on: August 21, 2022, 01:01:59 pm »
I have excessive grid hiss noise on one of (1) of (2) 6550 tubes. C308 270pf 1000 volt ceramic cap is my suspect. I swapped tubes and no change. All bias,plate,board resistor's and coupling cap's are new. As well as the 270pf cap. I am ready to un-solder C308 and replace again with the same cap and voltage values. BUT: Before i do i would like some input. Attached is a pic of the tube's/grid area.
I am using Doug's listening device.
« Last Edit: August 21, 2022, 01:07:55 pm by plexi50 »
Re: Sunn Grid Noise
« Reply #1 on: August 21, 2022, 01:14:43 pm »
Can i just snip it out all together? I don't see why not. :w2: NOT!
« Last Edit: August 21, 2022, 01:24:32 pm by plexi50 »
Re: Sunn Grid Noise
« Reply #2 on: August 21, 2022, 02:28:35 pm »
I don't get this. Remove C308 which is nothing more than a snubbing capacitor to me and i have no sound. The plate resistors are going to there respective coupling caps regardless of C308.
Re: Sunn Grid Noise
« Reply #3 on: August 21, 2022, 03:35:17 pm »
You obviously did more than just snip that cap. It's called collateral damage.
Re: Sunn Grid Noise
« Reply #4 on: August 21, 2022, 04:06:19 pm »
The circuit board and all components are where they should be. Working again with new 270pf 1KV cap. Crazy. Don't understand. Never seen this before. Don't make sense. Uploading a Video on my facebook page Triodeamplification.
« Last Edit: August 21, 2022, 04:21:32 pm by plexi50 »
Re: Sunn Grid Noise
« Reply #5 on: August 21, 2022, 04:28:23 pm »
Oh my god! I found the problem. I have a 820 ohm plate resistor instead of an 82K plate resistor. Man i really screwed the pooch. Back in a while with results. CRAZY DAYS ARE HERE AGAIN!
Re: Sunn Grid Noise
« Reply #6 on: August 21, 2022, 04:36:02 pm »
820R
Re: Sunn Grid Noise
« Reply #7 on: August 21, 2022, 04:58:30 pm »
You need to rewind a week when you said the amp sounded glorious. Quit fixin' if it ain't broke.
Re: Sunn Grid Noise
« Reply #8 on: August 21, 2022, 05:24:05 pm »
Yeah i need to slow down a bit. It was in the 82K bag i have. I don't know why i didn't see the orange marker. And yes it sounds even better. No more loud grid hiss through listening device.
Offline thetragichero
Re: Sunn Grid Noise
« Reply #9 on: August 21, 2022, 07:55:25 pm »
Re: Sunn Grid Noise
« Reply #10 on: August 22, 2022, 08:06:20 am »
https://www.ampbooks.com/mobile/amplifier-calculators/long-tailed-pair/calculator/
8k2 or 820r makes for a VERY unbalanced phase inverter
Yes it did. The reason i took the chassis out of the cab again was because i could hear abnormal hiss with the master at full CWR. And silent at CCW. Volume control were off. I used the listening device and when i probed each grid of the 6550 tube's, one of them was hissing away loudly. So i started looking at the PI and finally found my error. 820r in place of an 82K. The rest of the bag is full of 82K resistors. Still don't know how i missed it when i installed it. It is what it is. Cured now. And again,does sound very good.
