August 07, 2026, 12:53:43 pm
Hoffman Amps Forum image Author Topic: A little PT help, if you please..  (Read 5311 times)
Offline mmrxcsr01
« on: August 23, 2022, 10:01:34 am »
I have a P/T in hand that has BOTH primary wires as black. Is there any way to determine which I should route to the fuse and switch? It's an older Weber, and the wiring diagram I received with it shows the black as being correct for the age....thanks all, much appreciated.
Re: A little PT help, if you please..
« Reply #1 on: August 23, 2022, 10:06:18 am »
Connect the black to the switch/fuse. Connect the other black to the power cord neutral.
Offline Cirrus
« Reply #2 on: August 23, 2022, 10:13:03 am »
Sorry Sluckey, you've got that the wrong way round. It's actually BLACK that goes to the Switch/Fuse, and the OTHER black that goes to the power cord neutral.
Offline dude
« Reply #3 on: August 23, 2022, 10:37:24 am »
What, you just said the same thing as Sluckey said..!
Offline mmrxcsr01
« Reply #4 on: August 23, 2022, 10:38:52 am »
So if I read you right, it doesn't matter in this case, correct?
Offline thetragichero
« Reply #5 on: August 23, 2022, 10:41:35 am »
transformer don't care.
you just need to make sure the power from the wall is wired properly (line/black to fuse then switch then transformer, neutral/white to transformer)
« Reply #6 on: August 23, 2022, 01:16:19 pm »
I had it right for the U.S. You must be thinking about the U.K. wiring.  :wink:
« Reply #7 on: August 23, 2022, 02:32:50 pm »
if i remember correctly, uk amps with an attached power cord must switch both line and neutral
