September 14, 2026, 10:18:09 am
Hoffman Amps Forum image Author Topic: Another Sluckey AC15 Build - Troubleshooting  (Read 6319 times)
Offline ES125guy
« on: November 10, 2022, 09:11:41 am »
Hey everyone,
Long-time lurker, first time poster. Spent the past few months plugging away at building Sluckey's AC15. Pics for attention:
I've got sound/guitar output coming from both the normal and vibrato channels (woohoo!), but no vibrato. Swapped out the LED for a 1.5k resistor. Followed other threads  switchcraft 12a jack for footswitch, and connecting the ground and shunt, with the ground wire from the board going to the tip lug. Still no vibrato. Tried a couple different 12ax7 tubes for V6 and still getting low cathode voltage on pin 8 (4v).
Also noticed some questionable voltages on V1 pin 8, and V5 pin 6 (phase inverter). Here are my voltages for the entire amp. Curious if anyone has any ideas?
V1 - 12AX7
1-145v
2-
3- 1.2v
4- 5.9v ac across heater
5- 5.9v ac across heater
6- 240v
7-
8- 3v (should be 17v)
9- 5.9v ac across heater
V2 - EF86
1- 83v
2-
3- 3v
6- 81v
7-
8- 3v
9-
V3 - EZ81 (rectifier)
1- 281v ac (with tube installed)
2-
3- 342v
6-
7- 281v ac (with tube installed)
8-
9-
V4 - 12AU7
1- 87v
2-
3- 4v
6- 87v
7-
8- 4v
V5 - 12AX7 (phase inverter)
1- 234v (Should be 245v)
2- 35v
3- 76v
6- 328v (Way too high? Should be 243v)
7- 19v
8- 76v
V6 - 12AX7
1- 130v
2-
3- 2v
6- 242v
7-
8- 4v (vibrato to resistor or led) should be 23v
V7  - EL84
1-
2-
3- 11v
6-
7- 324v
8-
9- 328v
V8 - EL84
1-
2-
3- 11v
6-
7- 324v
8-
9- 328v
Letters below correspond to Sluckey's voltage testing points on http://sluckeyamps.com/VAC15/Vox_AC15.pdf:
A - 333v
B - 279v
C - 303v
D- 253v
Please excuse some of the questionable lead dress... Planning to tidy up more once I get things sorted out:
Appreciate any thoughts anyone might have on what to check next re: no vibrato and voltage on V1 and V5 PI.
Thanks!
Chris
Offline JPK
Re: Another Sluckey AC15 Build - Troubleshooting
« Reply #1 on: November 10, 2022, 09:37:44 am »
Tell you what those cabinets are artwork. Face plate too. Good luck, I'm sure you'll have it all sorted.
I love tubes
Offline ES125guy
« Reply #2 on: November 10, 2022, 10:29:37 am »
Thank you! I certainly hope so!
I spent a good bit of time on the aesthetics of the project. Concept is a 60's Brazilian knock off of a Vox. Turned the Vox crown logo into a humming bird feeder and changed the branding to Voz (voice in Portuguese). Copied Sluckey's faceplate and made some tweaks. Had it produced by Front Panel Express. I designed the badge from scratch and had a friend 3D print it. Cabinets are African Mahogany made by a raw cab seller on eBay out of Fresno, CA. I finished the cabs with sanding and Odie's oil and butter/wax.
Offline ES125guy
« Reply #3 on: November 10, 2022, 03:48:15 pm »
Discovered a bad connection on a jumper under the board near the PI. I fixed that and now V5 PI voltages are happy. Still no vibrato, however.
Updated voltage readings:
V1 - 12AX7
1-148v
2-
3- 2v
6- 246v
7-
V2 - EF86
1- 83v
2-
3- 3v
6- 81v
7-
8- 3v
9-
2-
3- 342v
6-
8-
9-
V4 - 12AU7
1- 87v
2-
3- 4v
6- 87v
7-
8- 4v
1- 218v
2- 22v
3- 62v
6- 229v
7- 24v
8- 62v
V6 - 12AX7
1- 199v
2-
3- 2v
6- 248v
7-
8- 5v (vibrato to resistor or led) should be 23v
V7  - EL84
1-
2-
3- 11v
6-
7- 324v
8-
9- 328v
V8 - EL84
1-
2-
3- 11v
6-
7- 324v
8-
9- 328v
A - 332v
B - 298v
C - 301v
D- 253v
« Reply #4 on: November 10, 2022, 04:26:54 pm »
Measure resistance between V6 pin 7 and ground. What have you?
Measure resistance between V6 pin 8 and ground. What have you?
Offline ES125guy
« Reply #5 on: November 10, 2022, 08:24:16 pm »
Pin 8 - maxed out 1. at 2M ohm setting not able to get a value
Pin 7 - fluctuates up and down between 450k to 730k ohm
« Reply #6 on: November 10, 2022, 08:41:04 pm »
That's a big clue. Reading should be 23.5K.
Check R55 and R52. Also be sure of the ground connection to R52.
Offline ES125guy
« Reply #7 on: November 10, 2022, 09:58:51 pm »
It just took some prompting from you. All fixed!!! Reflowed the top side jumpers in two parts of the vibrato circuit and now she sings! Thanks!!!
« Reply #8 on: November 10, 2022, 09:59:37 pm »
There should be a jumper between the two circled turrets. I don't see one.
Offline ES125guy
« Reply #9 on: November 10, 2022, 10:24:28 pm »
Indeed! That was part of it.
