September 15, 2026, 05:50:07 pm
Hoffman Amps Forum image Author Topic: 50 watt PT with a 100 Watt OT  (Read 4733 times)
Offline joesatch
  • save me from myself.
« on: January 04, 2023, 01:25:27 pm »
Trying to scrounge this build together. I have a 50 watt PT but my OT is for a 100 watt marshall. The 100 watt OT has 4 8 16 ohm taps.  Will those stay in place or do i need to halve something or double something? I'm running 2 x EL34
« Last Edit: January 04, 2023, 01:28:57 pm by joesatch »
Offline jordan86
Re: 50 watt PT with a 100 Watt OT
« Reply #1 on: January 04, 2023, 01:44:33 pm »
Pretty sure with just two EL34, the resistance on the primary side of the OT is double what the OT expects to see. Which means your secondary “doubles” as well. Effectively, those become like 8,16,and 32 ohm outputs.
Offline joesatch
« Reply #2 on: January 04, 2023, 01:48:34 pm »
So the same as pulling 2 power tubes in a 100 watt amp?  You connect an 8 ohm speaker cab to the 16 ohm OT tap?
Offline 66Strat
« Reply #3 on: January 04, 2023, 01:52:23 pm »
Your concern is the reflective load of the output transformer. Two output tubes want twice the load of four output tubes, i.e. connect 8 ohm speaker load 4 ohm tap or 16 ohm load to 8 the ohm tap. To verify this, compare the 50 watt output transformer specs to those of the 100 watt OT.
Regards,
JT
