September 17, 2026, 08:44:53 pm
Hoffman Amps Forum image Author Topic: 1974 Twin Reverb Transformer  (Read 4315 times)
Offline TenderTendon
  • Living in the past
« on: March 03, 2023, 03:46:08 pm »
I was troubleshooting a power supply recently, when I remembered I had an old Twin Reverb PT in the basement. I had everything set up on the bench, so I thought I'd test it too. I definitely got some unexpected results. Is this transformer hurt, or is it possible that the center tap is that far off?
You mess with the bull, you get the horns...
Re: 1974 Twin Reverb Transformer
« Reply #1 on: March 03, 2023, 04:02:06 pm »
Try a simple VAC test with your multi-meter and no caps or diodes.
A twin reverb high tension winding for a 2-phase voltage doubler is 185-0-185VAC
« Reply #2 on: March 03, 2023, 04:08:32 pm »
Looks like you have mistakenly used the bias tap for your center tap.
« Reply #3 on: March 03, 2023, 04:12:42 pm »
Damn it Sluckey! You got me again. Testing again......
« Reply #4 on: March 03, 2023, 04:28:12 pm »
Well, this is more like it...  335-0-335vac unloaded. 432vdc rectified and filtered. Good news is the transformer is good. Bad news is I have no use for it. Thanks again.
