September 16, 2026, 09:22:20 pm
Hoffman Amps Forum image Author Topic: SVT Bias and balance setting  (Read 53244 times)
Offline pbman1953
« on: April 24, 2023, 06:28:21 pm »
On my SVT setting the bias has no problem to set to .072 like the instructions state
With the balance ,the pot is not doing much to set to .01. The whole swing of the pot is .000
Plus it has a hum so it may be time for caps
Re: SVT Bias and balance setting
« Reply #1 on: April 24, 2023, 06:38:42 pm »
Open it up. Check the screen resistors . One of them may be blown open
Offline pbman1953
« Reply #2 on: April 24, 2023, 07:30:25 pm »
Thanks, I just bought this off a friend. It was a very good deal but I suppose it needs work. Since I'm not that familiar , I not sure if the hum that I hear is normal or that it needs caps. I thinking they need them because he told me that they were done around 2000.
The balance and hum pots are very noisy and need a cleaning.
I've watching some SVT repair videos and it seems that there's quite a few things to look for. One thing are the yellow box caps , if it has them. There's a history of 2 resistor's that go in the pre-amp.
On thing is that I tested the power tube heat and each one was around 90c. Not sure if that's common test but at least you know if a tube is running out of control.
The amp is still together. I was able to get my hand in there just to tap the pre-amp tubes . There's a a noisy JJ ECC 832, for channel 2 so I had a 12ax7 to  swap that out. That one makes channel 2 very scary. I may go with a lower gain.  The 6C4 was very noisy so I'd have to find one. A super light tap makes that go.
« Last Edit: April 25, 2023, 10:42:37 am by pbman1953 »
« Reply #3 on: April 25, 2023, 02:45:51 am »
Nope. First thing to check in those is the screen grid resistors. If one is open, it will throw out the output transformer current, resulting in hum. When all tubes are conducting, it’s easy to get the bias comparator working properly. So check those Rg2s with your R-meter. Which means taking the boards out. Sorry, it’s the only way to do it on a SVT-CL
Offline Latole
« Reply #4 on: April 25, 2023, 03:01:37 am »
If the tubes are very badly balanced / matched with too much difference they can generate hum.
Just measure the cathode current of each tube and you will know.
The filter caps; You have to measure the AC component on each of them. More than 0.3 volts, it is better to replace them. Otherwise they are not the cause of the hum.
Or if they show signs of damage; bubbles at the ends for example.
Wich SVT ?
Offline pbman1953
« Reply #5 on: April 25, 2023, 03:39:04 am »
1975
Offline Latole
« Reply #6 on: April 25, 2023, 03:54:26 am »
This one ;
removed incorrect schematic... sluckey
« Last Edit: May 03, 2023, 01:22:24 pm by sluckey »
Offline pbman1953
« Reply #7 on: April 25, 2023, 07:18:20 am »
This one ;
Thanks, which one is the pre-amp page?
Offline Latole
« Reply #8 on: April 25, 2023, 07:32:51 am »
Offline pbman1953
« Reply #9 on: April 25, 2023, 08:11:39 am »
Look here ; https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_Schematics.htm
I think it is this one;
Can you suggest where to go get the cap kit? I know that Fliptops carries it but I'm wondering where else I could go?
https://www.fliptops.net/catalog/p-100084/cap-kit-for-ampeg-svt-w6550-v.1
Offline pbman1953
« Reply #10 on: April 25, 2023, 08:14:51 am »
So you're saying all the 47k's off pin 5 to check?
« Reply #11 on: April 25, 2023, 09:00:20 am »
No. Screen grid is pin 3. Screen resistor is 22Ω.
Offline pbman1953
« Reply #12 on: April 25, 2023, 09:04:01 am »
yes yes, sorry had grid on my mind too much, thanks.
From what I see on the schematic there's only 1- can cap, but inside there are 2. Plus they are the same value 70/40/40. Looks like the only one available is a CE. Are there any ones better out there? I don't see JJ or F&T making ones that size.
Offline pbman1953
« Reply #13 on: April 25, 2023, 09:07:48 am »
Also, If I decide to update the grid resistors there's no wattage requirement unless I go 1/2 watt.
What rating would you all suggest?
Any suggestions for a 6C4 tube?
« Last Edit: April 25, 2023, 09:10:01 am by pbman1953 »
« Reply #14 on: April 25, 2023, 09:28:22 am »
Better verify you are looking at the correct schematic. What kind of power tubes are in your amp?
Offline pbman1953
« Reply #15 on: April 25, 2023, 09:31:46 am »
Valve Art- 6550. the tubes have a collar style lock at the base , not a spring and top plate system.
« Reply #16 on: April 25, 2023, 09:40:37 am »
Well then, the schematic posted by Latole is not the one you need. Look through Hoffman's schematic and find the correct schematic.
Offline pbman1953
« Reply #17 on: April 25, 2023, 09:47:52 am »
I think it's this one. It has the 7-/40/40 can cap shown
« Last Edit: May 03, 2023, 01:29:00 pm by sluckey »
« Reply #18 on: April 25, 2023, 09:50:13 am »
Nope. Wrong power tubes.
Offline pbman1953
« Reply #19 on: April 25, 2023, 09:52:12 am »
you're right, maybe the earlier version.I'll check around
Offline Latole
« Reply #20 on: April 25, 2023, 09:56:46 am »
I never buy a capacitor kit, it's too rare and there are too few good ones.
You will have to buy them by the unit, choosing according to the MFD and voltage values and taking into account the physical dimensions.
You will have to take the values on the parts actually in your amp, not trust the schematic.
Where is your location; North America or Europe to give you the right references
Offline pbman1953
« Reply #21 on: April 25, 2023, 10:00:56 am »
Boston
I found most if not all from Antique supply in AZ. Very easy site . The carry the CE multi cap, F&T & Sprague
The only odd one was the 30uf/600v. An odd item , but I found a 30/500v.
Any suggestions on the 6c4 tube?
Offline Latole
« Reply #22 on: April 25, 2023, 10:24:43 am »
I know very well Antiques
You are looking to buy a 6C4 tube ?
Offline pbman1953
« Reply #23 on: April 25, 2023, 10:28:27 am »
I found this one that has 6550's.
I suppose the the cap section outlined with dashes are the can caps?
« Last Edit: May 03, 2023, 01:30:25 pm by sluckey »
Offline pbman1953
« Reply #24 on: April 25, 2023, 10:29:12 am »
Yes, it's too sensitive and noisy even touched
« Reply #25 on: April 25, 2023, 10:35:29 am »
In reply #2 you mention 6V4. In reply #13 you mention 6C4. Which is it? They're totally different tubes.
Offline pbman1953
« Reply #26 on: April 25, 2023, 10:39:24 am »
Sorry for making people crazy-
6C4
« Reply #27 on: April 25, 2023, 10:41:50 am »
That's much closer. However, the two cap cans are different values. You mentioned earlier that the two cans in your amp are the same?
Offline pbman1953
« Reply #28 on: April 25, 2023, 10:45:11 am »
Well I'm basing my caps on the Fliptops parts list. I'll go by what Latole said and open it and make a real parts list.
Offline pbman1953
« Reply #29 on: April 26, 2023, 07:44:44 am »
From moving the 6c4 in and out of the socket it may be making a better connection and it's not that noisy. One thing, it's sensitive to tapping like the most v1's are. Besides that it's quiet. Is this normal for that position and tube?
Couple more questions-
In my search for a 30uf / 600v, the most I can find is a 30/500v. Will that be ok or should I try for a higher value at 500v? or what combo would be safe?
For those who've done an SVT are there any tell tale things to look for and change with out testing?
« Last Edit: April 26, 2023, 07:47:43 am by pbman1953 »
Offline Latole
« Reply #30 on: April 26, 2023, 07:57:49 am »
 "  One thing, it's sensitive to tapping like the most v1's are. Besides that it's quiet. Is this normal for that position and tube? "
Yes, all V1, any tube, are noisy when tapping
Filter caps  ; two 50 mfd 300 volts ( or more ) in series = 25 mfd 600 volts
« Last Edit: April 26, 2023, 08:03:25 am by Latole »
Offline pbman1953
« Reply #31 on: April 26, 2023, 08:08:06 am »
The 6C4 is v4, would that matter? I'm saying by being tapped it reacts like a v1 would
Thanks for the cap info!
Also, for one of the can caps, I found a 80/40/40 for the 70/40/40 stock size. Should I go with the 80uf or stay with the stock value?
« Last Edit: April 26, 2023, 08:16:28 am by pbman1953 »
Offline Latole
« Reply #32 on: April 26, 2023, 10:34:46 am »
6C4 ; sorry for my mistake.  I don't know .
Read here ; "....that they're prone to microphonics in general and their use in the SVT doesn't help that. "
https://www.talkbass.com/threads/ampeg-svt-6c4wa-tube.1315801/
Offline pbman1953
« Reply #33 on: April 26, 2023, 10:39:33 am »
Maybe I should get one
Offline pbman1953
« Reply #34 on: April 27, 2023, 11:15:32 am »
I found  2 MoD caps at 70uf/350.  Is that over kill? 35/700v
Offline Latole
« Reply #35 on: April 27, 2023, 11:21:15 am »
Good choice these MOD
Offline pbman1953
« Reply #36 on: April 29, 2023, 09:59:25 am »
First report-
This amp has never had a cap job. kind of sad to see and I hope my friend didn't pay for one on the service calls he had done.
Pre-amp-
Should the yellow box caps be replaced?
Change the yellow box caps and silver 40/450v caps?
Power amp-
This amp has 2- 100/40@450v volt caps. Not the 70/40/40 that i expected
100@ 450v
90 @200V
30@600V
Should I cut out the .047 white death cap?
Tube sockets-
The 47K's measure from 38-40k. Even the larger one on the end tube socket
22 ohm screen resistors-
5 measure- avg of 22.9
1- won't measure
Change them all or only the bad one?
Are here any other recommended parts to check?
« Last Edit: April 29, 2023, 10:05:32 am by pbman1953 »
Offline pbman1953
« Reply #37 on: April 29, 2023, 10:00:02 am »
more pics
Offline pbman1953
« Reply #38 on: April 29, 2023, 11:14:30 am »
More tests-
5 ohm @ 5 w- power resistors-r's-27,30,32,38,41,44
5 measure- around 6
1- won't measure- should I replace only the bad one or all?
For r's- 35 & 36- 1 ohm @ 5w- They're at 2 ohm and not 1 ohm.- replace?
Offline pbman1953
« Reply #39 on: April 29, 2023, 06:22:43 pm »
power amp
Offline Latole
« Reply #40 on: April 30, 2023, 04:33:40 am »
More tests-
5 measure- around 6
These are all goods, no need new one
Offline pbman1953
« Reply #41 on: April 30, 2023, 06:14:16 am »
Thanks but here's a few questions that may have slipped by-
1- Should I cut out the .047 white death cap?
2- 22 ohm screen resistors- 5 measure- avg of 22.91
1 won't measure.- replace all or only the bad one
possible tube subs-
Original value - 90uf@200v - I have an JJ- 80uf @500- use the 80 or get the 90?
The 47K resistors off pin 5  measure from 38-40k. Even the larger one on the end tube socket-   I bought new ones anyway
« Last Edit: April 30, 2023, 06:42:11 am by pbman1953 »
Offline Latole
« Reply #42 on: April 30, 2023, 06:41:04 am »
I think you are brave and hardworking to start repairing this amp with so little knowledge of electronics :thumbsup:
Offline pbman1953
« Reply #43 on: April 30, 2023, 06:45:18 am »
Thanks, I have an extensive background in car audio. So I've soldered a lot and have designed and installed some amazing systems. Many with 5.1 processors from Jim Fosgate the father of more current Dolby pro-logic.
Plus, with the help of the forum and some other techs, I'm gone through my Traynor YBA-3, Sunn 2000s & converted a Fender '75 Super twin into a bass amp. My first help on that was a tech from NJ Adam who used to work with Dennis Kager, from Central Music. Adam is an SVT expert. Dennis was the service manger at Ampeg/Magnavox before opening Central Jersey Music.
« Last Edit: April 30, 2023, 06:49:27 am by pbman1953 »
« Reply #44 on: April 30, 2023, 11:50:42 am »
No need since you have a properly wired three prong power cord. It's not a death cap. It's simply a line filter connected between neutral and ground.
I would replace only the one that won't measure.
Offline pbman1953
« Reply #45 on: April 30, 2023, 12:06:45 pm »
I have a xcion 100@450v. Ok to use that or get a better one?
Offline Latole
« Reply #46 on: April 30, 2023, 01:56:05 pm »
Both will work.  JJ or Xicon
Offline pbman1953
« Reply #47 on: May 01, 2023, 06:52:25 am »
a question on security-
I sent a picture of the clamps that hole 2 caps. My question is if  can use a mounting tie -
https://www.homedepot.com/p/Commercial-Electric-8-in-UV-Mounting-Cable-Tie-Black-10-Pack-GTM-200STB-10/203531941
Offline Latole
« Reply #48 on: May 01, 2023, 06:55:34 am »
« Last Edit: May 01, 2023, 06:58:43 am by Latole »
Offline pbman1953
« Reply #49 on: May 01, 2023, 07:00:45 am »
Yes.
thanks!,
In the pre-amp there's a 40uf@450V electrolytic  want to change. I have another JJ- 80uf@450, will that work or should i stay with the 40?
« Last Edit: May 01, 2023, 07:07:32 am by pbman1953 »
