September 23, 2026, 11:16:37 am
Hoffman Amps Forum image Author Topic: SUNN Sorado Project  (Read 6700 times)
Offline AHeck
SUNN Sorado Project
« on: June 11, 2023, 08:24:56 pm »
Good evening,
I've Been working on this bass amplifier for a few weeks.  I've replaced quite a few components and reworked the ground scheme, replaced nonfunctioning boost switches, reflowed some solder, etc. In working on it, I noticed where the schematic did not match the actual wiring. I will post schematics. I was wondering if you all might help me determine if the schematic is wrong and it came to me as per the factory, or if the schematic is right and someone had been in the chassis before me and made some mistakes.
Offline AHeck
Re: SUNN Sorado Project
« Reply #1 on: June 11, 2023, 08:28:55 pm »
So the first boost circuit does not match the wiring. Here is the first tube schematic followed by the circuit as it was wired.
Offline AHeck
« Reply #2 on: June 11, 2023, 08:30:51 pm »
This is the second tube, and the lil' capacitor was in a different spot than the print.
Offline AHeck
« Reply #3 on: June 11, 2023, 08:45:58 pm »
Also, while I got you...
It still has a loud hum. With signal applied with a frequency generator, if I flip the power switch, The hum goes away immediately and the signal tone is left to fade out with a dead quiet background.  The way the heaters were run is terrible, wires not twisted and very long parallel runs with signal cable.  That's what I'm betting is the problem and I'm going to redo that, too.  Is this reasonable?
« Reply #4 on: June 12, 2023, 07:49:53 am »
I would think your "as wired" schematic is correct. I would not mess with the heater wiring. Sunn knew what they were doing and the way they ran the filaments works just fine. Look to the power supply and/or the power tubes for your loud hum.
BTW, the Sunn Sonaro (EL34 version of the Sorado) was the first guitar amp I ever built back in '68.
« Reply #5 on: June 12, 2023, 10:50:34 am »
Hi guys
Please can you explain me what happen around V1b ?
The presence of the switch with the 10M resistor in parallel confuses me
If the switch is open I don't think the signal will pass ......
Decisely there is something that I don't arrive to understand
..... OK, the signal from V1a feeds V1b via the .002 capacitor ..... is the other cap with the pot present as a tone control ?
« Last Edit: June 12, 2023, 10:54:43 am by kagliostro »
« Reply #6 on: June 12, 2023, 11:02:01 am »
There is a .002 coupling cap between V1A plate and the top of the volume control. When you close the switch you place a .0075 cap in parallel with the .002 cap for a total capacitance of .00095 (just call it .01). This allows more low frequency signals to pass. It's called a LO BOOST. The 10M just prevents any popping noise from the switch.
Offline AHeck
« Reply #7 on: June 12, 2023, 12:17:06 pm »
Thanks, I thought the schematic was incorrect.  I especially appreciate the explanation, now I understand how that works.
« Reply #8 on: June 12, 2023, 01:04:01 pm »
I think either way will work but your "as wired" schematic just seems more politically correct.
« Reply #9 on: June 12, 2023, 04:58:00 pm »
The way it was wired is much easier to be understand, the other way, as per the schematic, is still confusing
But as wired all is clear
« Reply #10 on: June 13, 2023, 08:47:25 am »
I asked to a friend to help me to understand better and he confirmed what Sluckey told, both arrangement are functional
So an idea come out
Why don't use an SPDT with the center pin connected to the .002 cap and the other pin connected one to the wiper and one to the pin of the pot that isn't connected to ground
So you can easily compare and decide which arrangement is better for you
