September 15, 2026, 10:45:02 pm
Hoffman Amps Forum image Author Topic: New Fender Bassman 6G6-B Build Questions  (Read 20833 times)
Offline Dave
Re: New Fender Bassman 6G6-B Build Questions
« Reply #50 on: July 02, 2023, 02:27:25 pm »
As you lower the bias voltage to bring bias current up, the B+ voltage will drop even more. So, yes, I would use a higher voltage tap.
Dave
Offline 72Blazer
  • Long live rock!
« Reply #51 on: July 02, 2023, 02:39:08 pm »
Definitely will do one or the other.  I think I have a 10k pot around here somewhere.
Offline 72Blazer
  • Long live rock!
« Reply #52 on: July 02, 2023, 04:53:50 pm »
Confirm I can wire this Bias pot into this amp using the bias adjustment as the AA864 Layout?  Using a 10K resistor of course.
« Reply #53 on: July 02, 2023, 05:28:46 pm »
This is what I suggested. This allows you to smoothly vary that resistor across the bias cap from 15K to 25K. Just add the red jumper to the pot.
Offline 72Blazer
  • Long live rock!
« Reply #54 on: July 02, 2023, 06:13:06 pm »
OK, I did as Sluckey suggested (jumper).  I am using the red pair of the PT wires.  I got 465v at the plates so I set the bias to 44mA using the 1ohm resistors on pin 8s.  I'm still contemplating installing a multi impedance swicth for the OT as it has 2, 4, and 8 ohm taps.  I'm using the 4 ohm tap for now.  I still have some lead dress work to do but I thought I would share some pics of the build.
« Reply #55 on: July 02, 2023, 06:50:07 pm »
I don't trust the solder job on that chassis ground. Looks like you could take a screwdriver and hammer and with a couple light taps just pop that solder blob off the chassis. Takes a LOT of heat with a powerful iron or gun to make a secure solder connection to a chassis. Using a ring terminal, screw, and kep nut would be a much better ground connection.
Offline 72Blazer
  • Long live rock!
« Reply #56 on: July 02, 2023, 07:08:13 pm »
Noted Sluckey.  I will re-attack that ground.
Vr
J
Offline 72Blazer
  • Long live rock!
« Reply #57 on: July 02, 2023, 09:54:12 pm »
Gents FWIW, I've been playing this amp off and on all night.  Takes my pedals (reverb, delay and a analogman SD-1) very nicely.
The cleans are very nice indeed and when you push it with the volume control on the guitar (G&L 2HB) it growls...
I am sold on this Bassman circuit.  The "Presence" is a cool feature as well.
Time to enjoy this little victory with a stiff Buffalo Trace Bourbon!
Vr
J
Offline 72Blazer
  • Long live rock!
« Reply #58 on: July 13, 2023, 07:35:51 pm »
Thought I would give an update on this amp.
I reattacked that solder joint and it is now a good weld to the chassis now.  I will definitely heed the recommendation for kep nut grounds on future projects.
I added a pot and resistor (exactly as Sluckey recommended below) to control the bias to the tubes.
I initially left out the .002uf cap in the the Bass channel, but my guitarist buddy (using guitar) says it sounds better with the cap in the circuit.  I have a "Cap Substitution" box and we "real time" tried different cap values in the circuit.  IMHO, leaving this .002 cap out did produce more highs-which to me added gain.  There is still a lot of tone control either way using the trebel and bass knobs.  So basically I am indifferent to that mod-which obtw I came across on some thread.
again, this is my opinion only.
Lastly, the bass channel is louder than the normal channel and gets more gain (using a guitar) than the normal channel.
This amp would be a great candidate for putting AB swich in front and using the bass channel for leads.
Thanks again to the incredible talent/experience shared on this website.
Vr
J
