August 07, 2026, 05:52:16 am
Hoffman Amps Forum image Author Topic: KUSTOM DEFENDER 112 TUBES OFF  (Read 7867 times)
Offline Travis8
« on: July 19, 2023, 11:53:07 am »
Hi everyone!!
I have a kustom defender 112 that doesnt turn on power tubes..
I check fuses and they are all ok, I read pin 2 and 7 witch correct 6.3vac and the test point on the amp looks correct values... also I resolder all the pinout
Some ideas o recommendation?
Thanks.
https://el34world.com/charts/Schematics/files/Kustom/Kustom_defender112.pdf
Offline Travis8
Re: KUSTOM DEFENDER 112 TUBES OFF
« Reply #1 on: July 19, 2023, 12:07:08 pm »
between GND and F4 is 3.2VAC, also F4 is ok.
Offline Travis8
« Reply #2 on: July 19, 2023, 12:09:40 pm »
They doesnt light up and the amp doesnt sound. 12ax7 looks fine
« Reply #3 on: July 19, 2023, 12:51:00 pm »
Set meter to read AC volts. Connect one probe to pin 2 of an EL34. Connect the other probe to pin 7 of the same EL34. What voltage do you have?
« Reply #4 on: July 20, 2023, 01:10:55 am »
Did you had a filament chek ?
Offline Latole
« Reply #5 on: July 20, 2023, 03:26:32 am »
This look good , follow Slukey advice.
Offline Travis8
« Reply #6 on: July 20, 2023, 10:35:11 am »
I turn it on right now to check it and the tubes shine!!!!!!!! I dont understand why yesterday not... Some ideas ?
I read 6VAC.
Offline Travis8
« Reply #7 on: July 20, 2023, 10:41:39 am »
I check that the amp turn on and the tubes lights up and the amps sound, but after a minute they amp starts sound quieter and quieter and finally it haves no sound and no light on tubes.
« Reply #8 on: July 20, 2023, 11:15:21 am »
Leave your meter connected to measure filament voltage as I said earlier. What voltage do you have when the lights go out? I suspect the filament current is causing a poor connection to open up. Top suspects would be J34 and J35. It's a very simple circuit. Should be easy to find.
Offline Travis8
« Reply #9 on: July 20, 2023, 12:10:52 pm »
When I turn it on 6.04VAC, then its starts going down step by step after a minute, and finally when tubes stop light AC is: 0 VAC its still sound a little bit with 0VAC but finllay stop sound.
« Reply #10 on: July 20, 2023, 01:07:48 pm »
As I suspected.
Other suspects would be a bad connection at the fuse holder or tube socket or even a bad trace on a circuit board if filaments are run on the pcb.
Offline Travis8
« Reply #11 on: July 21, 2023, 04:27:17 am »
As I suspected.
J34 and J35 looks good. How can I check it properly?
Offline Travis8
« Reply #12 on: July 21, 2023, 04:49:19 am »
Photos
Offline Travis8
« Reply #13 on: July 21, 2023, 05:02:28 am »
I check continuity and J35 goes correctly to R101 and pin 2 in both tubes and J34 goes correctly to fuse holder, R102 and pin 7 in both tubes.
Offline Travis8
« Reply #14 on: July 21, 2023, 01:49:39 pm »
I'm a bit lost, some ideas?
Thanks you everyone, for real.
« Reply #15 on: July 21, 2023, 02:19:39 pm »
Do you still have 6VAC between J34 and J35 when the lights go out? If so,
Reflow the solder connections for J34, J35, the fuse holder, and pins 2, 7 of the power tubes. Look for a broken pcb trace between J34, J35, the fuse holder, and the output tubes.
If you do not have 6VAC between J34 and J35 when the lights go out, examine the wire between J34, J35, and the PT. If this is the case then the PT is likely bad.
« Reply #16 on: July 21, 2023, 04:59:40 pm »
This may help. Re-flow all the solder pads I circled, top and bottom of board.
Offline Travis8
« Reply #17 on: July 22, 2023, 01:32:25 pm »
I resolder it and also I check that J34 cable was a little bit bad. Now itīs works!!!
Thanks!!!
