September 25, 2026, 07:18:16 am
Hoffman Amps Forum image Author Topic: ENGL Savage 120 low bias  (Read 16206 times)
Offline Travis8
« on: July 22, 2023, 01:34:05 pm »
Hi!
I check my engl savage 120 bias and is 18ma for one KT88 and 17ma for the other one, they are news and I changue it becouse I notice that the amp was a little bit quieter than It should be.
Did someone experiment something similar?
Offline Travis8
Re: ENGL Savage 120 low bias
« Reply #1 on: July 22, 2023, 01:37:56 pm »
Red leds are on In the tubes, the manual said that:
Power Tube Monitor
This red LED lights up to indicate one of the internal power tube fuses has blown. You can continue playing,
but the amp‘s performance will be diminished. Normally the loss of a power tube results in an unbalanced
signal. Be sure to have a specialist look over the power amp as soon as possible; the fuse probably blew
because of a defective power tube. Once a fuse has blown, it must be replaced by a new fuse.
I will check it..
Offline Latole
« Reply #2 on: July 22, 2023, 02:24:20 pm »
« Last Edit: July 22, 2023, 02:55:23 pm by Latole »
Offline Travis8
« Reply #3 on: July 24, 2023, 03:35:18 am »
Offline Latole
« Reply #4 on: July 24, 2023, 03:49:15 am »
Bias ma reading work with voltage. Only ma mean nothing
What is the plate voltage ?
  KT88 = 42 watts maximum tube dissipation.
I mostly bias at 50 to 60 % power dissipation ; 50 % = 21 watts
Let say : If tube plate voltage is 500 volts ( check your amp )
500 volts X 18 ma = 9 watts,  A way too low. A weak tube may read that. Put new one.
With good tube ;  you must adjust bias ( grid) negative voltage
Offline Travis8
« Reply #5 on: July 24, 2023, 05:43:10 am »
I tried with new tubes and bias is 18ma, let me read plate volts..
Offline Travis8
« Reply #6 on: July 24, 2023, 11:15:47 am »
around 580 volts but just 18ma
« Last Edit: July 24, 2023, 11:56:13 am by Travis8 »
« Reply #7 on: July 24, 2023, 12:28:55 pm »
Check bias according to the manufacturer's procedure. What have you?
Offline Latole
« Reply #8 on: July 24, 2023, 01:36:02 pm »
580 X 18 = 10.4 watts.
 Tubes will last 100 years and more
Follow Sluckey advice.
Offline Travis8
« Reply #9 on: July 25, 2023, 11:10:36 am »
0,8 volts and 0,680.
0,680 side starts coming down little by little, after 10 minutes I read 0,614. Then no more drop and still 0,614... I check it for 20 minutes.
Offline JPK
« Reply #10 on: July 25, 2023, 11:15:59 am »
Well there's your problem. Now how to raise it.
I love tubes
Offline Travis8
« Reply #11 on: July 25, 2023, 12:06:59 pm »
I´m thinking about it, could be a output transformer issue, bias trimmer in middle position; 0,222 volts
« Last Edit: July 25, 2023, 12:14:59 pm by Travis8 »
« Reply #12 on: July 25, 2023, 12:22:31 pm »
OK, that confirms the mA readings from your first post. Now measure the negative dc voltage on pin 5 of each KT88. Also measure the dc voltage on pin 4 of each KT88. What have you?
Offline Travis8
« Reply #13 on: July 25, 2023, 12:33:24 pm »
Around 410v on pin 4 and -59v on pin 5
« Reply #14 on: July 25, 2023, 12:46:09 pm »
Those voltages look fine. Now measure the voltage on pin 8 of both KT88s. What have you?
Offline Travis8
« Reply #15 on: July 25, 2023, 12:55:30 pm »
0 volts on pin 8
Power tubes fuses are ok
« Last Edit: July 25, 2023, 12:59:15 pm by Travis8 »
« Reply #16 on: July 25, 2023, 01:15:30 pm »
That rules out everything except the tubes and the OT.
Offline Travis8
« Reply #17 on: July 25, 2023, 01:19:19 pm »
Tubes are new...
« Reply #18 on: July 25, 2023, 01:48:45 pm »
0 volts on pin 8
just to cover the odd things;
NO power
ohm pin 8 (tube side) to the ground side of the STBY switch, both sockets
do it with the switch closed and open
« Reply #19 on: July 25, 2023, 03:19:40 pm »
Tubes are new...
Put the old tubes back in and recheck the bias.
Offline Deric
« Reply #20 on: July 25, 2023, 03:34:58 pm »
It's not very clear so just to be sure...  Here you say "bias trimmer in middle position". Have you actually adjusted the bias trimmer?  What's the DC voltage on pin 5 when the bias trimmer is all the way CW (clockwise)?  Voltage on pin 5 all the wy CCW (counter clockwise)?
Offline Latole
« Reply #21 on: July 25, 2023, 03:40:54 pm »
Yes, turn this trimmer to reduce negative bias voltage
Offline Travis8
« Reply #22 on: July 26, 2023, 04:10:00 am »
0 volts on pin 8
NO power
pin 8 of both sockets to ground stby switch 0 ohms, to the other side of the stby switch 82.6ohms
Offline Travis8
« Reply #23 on: July 26, 2023, 04:35:52 am »
If I use old tubes with bias trim all the way down, pin 5  read 0 volts.
With new tubes, PIN 5:
All the way up:  -49.0
All the way down:-62.8
Offline Latole
« Reply #24 on: July 26, 2023, 04:51:41 am »
At -49 how many ma did you read ?
More than 18 ma ?
From -59 you read first, you may go over 20/ 25 ma
Offline Travis8
« Reply #25 on: July 26, 2023, 04:53:17 am »
More than 18 ma ?
I read with all the trimmer way down around 7/9ma and with the trimmer all the way up I read around 33/35ma
Offline Latole
« Reply #26 on: July 26, 2023, 05:10:47 am »
With these readings you can have the right bias.
Do calculation as I show you.
Dont forget ; more ma = less plate voltage
check after each adjustment
__________________________
« Last Edit: July 26, 2023, 05:13:01 am by Latole »
Offline Travis8
« Reply #27 on: July 26, 2023, 05:23:02 am »
I read the bias like the schematic said and I can get 1,5volt max...
I assume is ok?
I get around 19 watt if I calculate with plate and ma, is less than 50%.
« Last Edit: July 26, 2023, 05:48:54 am by Travis8 »
Offline Travis8
« Reply #28 on: July 26, 2023, 05:57:14 am »
is I read bias like schematic said I move the trimmer to get right now: 1.447v
with this position I get:
34ma and 563v, so it´s 19.142 watts
its fine?
Offline Latole
« Reply #29 on: July 26, 2023, 06:15:08 am »
That is very good  ! On both tubes ?
Did you read carefully my answer ?
"I mostly bias at 50 to 60 % power dissipation ; 50 % = 21 watts"
19.42 watts Is very good
Offline Latole
« Reply #30 on: July 26, 2023, 06:16:37 am »
How did amp sound now ?
Offline Travis8
« Reply #31 on: July 26, 2023, 07:42:20 am »
I read the other tube, is: 18.938w
and following the schematic is: 1.37v
« Last Edit: July 26, 2023, 08:42:22 am by Travis8 »
Offline Latole
« Reply #32 on: July 26, 2023, 02:42:19 pm »
Il bias the higher tube to 21%
How is the amp sound now ?
After the right bias, if amp sound powerful and good, job is done
« Last Edit: July 26, 2023, 03:03:42 pm by Latole »
Offline Travis8
« Reply #33 on: July 28, 2023, 04:11:52 am »
Its look fine, I think the problem was the range of the bias pot is all in 1/2 mm. and the rest is under volt.
Thanks!!
Offline Latole
« Reply #34 on: July 28, 2023, 04:39:19 am »
Said thank to Deric , post #20.
It is him write to turn the pot.
If pot is so sensitive ( show picture) I will replace it by a less sensitive one , a better one.
Your pot may move with time. This is what happened
« Last Edit: July 28, 2023, 04:43:32 am by Latole »
Offline Latole
« Reply #35 on: July 28, 2023, 04:44:18 am »
I sometimes see these pots, they are not good ;
