September 25, 2026, 05:07:14 pm
Hoffman Amps Forum image Author Topic: 1/4 watt resistor crisis  (Read 7188 times)
Offline joesatch
  • save me from myself.
« on: July 24, 2023, 08:00:25 pm »
ran out of 1 watts dont have any 1/2 watt. working on a tonestack circuit so the voltages should be pretty low. can i use 1/4 watt resistors?  specifically 1/4 watt into preamp grid?
Offline bmccowan
  • Better builder than player
Re: 1/4 watt resistor crisis
« Reply #1 on: July 24, 2023, 08:48:57 pm »
First - my Mainer answer; don't matter to me.
Next - I suspect if you do the math - it's fine. Bunches of reissue PCB based amps use them.
Next - I wouldn't, given that I could get the resistors the project deserves in a few days for cheap money. You work on a lot of amps - why not just order up a whole kit of all values. Its so nice to have what you need on hand.
Mac
John Prine
« Reply #2 on: July 25, 2023, 12:19:27 am »
The bigger the resistor the low the intrinsec noise
I use metal film 2W resistors and bigger where required
I can see them better, they have a better look on the Board and I can handle in an easier way than the invisible 1/2 - 1/4 ones
Offline dwinstonwood
« Reply #3 on: July 25, 2023, 04:29:47 am »
I just bought a bunch of 600mW (0.6 Watt), 1% Vishay's in all of the typical guitar amp values. I had always searched for and bought 1/2 Watt's in the past.
The Vishay MBx/SMA - Professional series has a huge range of values.
I even bought some 90.9K's, a weird value that can balance LTP outputs much closer than the usual 82K (if that's what you want).
They averaged about 26 cents a piece @ 10 or more, so a paid a bit more for them.
Just go to your favorite online electronics supplier and apply these filters:
Metal Film-Through Hole
Vishay
600 mW
1% Tolerance
MBx/SMA Series
« Last Edit: July 25, 2023, 04:49:16 am by dwinstonwood »
« Reply #4 on: July 25, 2023, 06:58:39 am »
With resistors, watch out for their voltage rating. Many types have a 250V limit, standard sub 1W is 350V.
« Reply #5 on: July 25, 2023, 08:30:56 am »
Thanks pdf64.
The Vishay 600mV series I referenced above do have a 350V rating:
https://www.mouser.com/ProductDetail/Vishay-Beyschlag/MBB02070C9092FC100?qs=LkqrmUh5PII7wRxfAHYqwA%3D%3D
Offline dbishopbliss
    • Bliss Amplifiers
« Reply #6 on: July 25, 2023, 10:57:55 am »
What change (improvement???) do you notice by having the outputs more balanced?
Check out my blog for more details. Bliss Amplifiers
« Reply #7 on: July 25, 2023, 02:34:07 pm »
I would say none!  :icon_biggrin:
I was playing with this calculator, and 90.0K gets darn close, so, why not? I bought some.
https://www.ampbooks.com/mobile/amplifier-calculators/long-tailed-pair/calculator/
But, I don't think my ears would notice a difference.  :dontknow:
Offline joesatch
« Reply #8 on: July 25, 2023, 03:03:09 pm »
i found a hack. so i am good!
« Reply #9 on: July 25, 2023, 10:44:45 pm »
WHAT "tonestack"?
But for argument/example, the usual Fender stack played LOUD may have 100Vrms across the first 100k resistor.
100V^2= 10,000
10,000/100,000 is 1/10 Watt
