September 25, 2026, 10:12:16 am
Hoffman Amps Forum image Author Topic: how to place the components?  (Read 6130 times)
Offline roseblood11
    • Layouts and Pictures
« on: July 25, 2023, 11:08:41 am »
What do you think of this arrangement of the components?
The amp is based on the 6g3 Brownface Deluxe, but with an AB763 channel and the tremolo from the 6g16 (two triodes).
Offline acheld
Re: how to place the components?
« Reply #1 on: July 25, 2023, 01:42:55 pm »
I'd want to move that OT closer to the middle of the chassis, away from V1, and closer to the output section of the circuit.  Yeah, I know holes are already there, but a couple more won't hurt . . .
Consider moving the rectifier to just above the PT, where your relay PS is, that will free up some space.
V1-3 look very closely spaced to me; I guess that could work, maybe.
Ahhh, the joys of a re-used chassis!
Offline roseblood11
« Reply #2 on: July 25, 2023, 02:30:32 pm »
Nostalgia... This was my first tube amp, a Carvin Vintage 33, it's almost 30 years old
« Reply #3 on: July 25, 2023, 05:07:16 pm »
put the fuse on the back wall next to the recep.
put the switchboard on the bottom side of PT, use the PT bolts to cobble the switchboard
put the Rec tube where the switchboard is
move the PI one hole left away from the preamp
Offline roseblood11
« Reply #4 on: July 26, 2023, 07:39:27 pm »
Better?
« Reply #5 on: July 27, 2023, 04:53:48 am »
you really don't want large signal producing stuff anywhere near sensitive signals
Offline roseblood11
« Reply #6 on: July 27, 2023, 05:07:12 am »
It was no problem in the old Carvin amp. It didn't even have tube shields.
« Reply #7 on: July 27, 2023, 10:33:15 am »
At this point, we don’t know what mitigation was used to manage that  :dontknow:
I suggest to lay out the build like the schematic; inputs stuff at one end, output stuff and power supplies at the other.
Offline roseblood11
« Reply #8 on: July 27, 2023, 12:11:26 pm »
The problem is If I move the OT to the left, the power tubes must be closer to the preamp tubes.
