September 26, 2026, 02:32:12 am
Hoffman Amps Forum image Author Topic: Mosfet reverb recovery  (Read 8759 times)
Offline Bieworm
  • I like it loud!
« on: August 02, 2023, 04:52:35 am »
Hi guys
I’ve been looking a lot at circuits with mosfets substituting triodes in tube amps. I always end up with circuits that have a mosfet cathode follower, but I would like to try an IRF840 in the recovery part of an AB763 reverb circuit. Has anyone got a schematic for such application?
Re: Mosfet reverb recovery
« Reply #1 on: August 02, 2023, 06:07:14 am »
I know an LND150 is used as a recovery in active FX loop designs.  See reply #33 in FX loops from the ARCHIVES:
tube effects loop on board (el34world.com)
I have not used one, but I'm thinking that perhaps it could be used as a reverb recovery?
Hopefully, someone more knowledgeable can offer a more educated answer.
Offline Bieworm
  • I like it loud!
« Reply #2 on: August 02, 2023, 06:36:47 am »
Is it an idea to test this on an amp doing the following?
Pull the recovery tube, clip in an LND150 mosfet on both triodes with each a back to back 12V zener from cathode to grid? And leave all other connections as they are. Or are there other values that would definitely need to be changed?
« Reply #3 on: August 02, 2023, 07:18:11 am »
Hi guys
Sub the ckt at the top of the page for a triode gain stage - For reverb tank recovery, you don't need ZD1 & ZD2. An IRF840 to do the job is overkill.
http://www.hawestv.com/amp_projects/amp_solid_tube/fetpreamp_200v1.htm
--Pete
Offline Bieworm
  • I like it loud!
« Reply #4 on: August 02, 2023, 07:27:41 am »
Hi guys
--Pete
Thanks Pete! That is exactly what I was looking for👍👍👍
Offline Greenwichpaul
  • I love valve amps
« Reply #5 on: August 02, 2023, 03:42:34 pm »
This thread includes a LND150 recovery stage that has been used successfully, last post.
https://el34world.com/Forum/index.php?topic=27722.0
« Last Edit: August 03, 2023, 06:57:03 am by Greenwichpaul »
« Reply #6 on: August 02, 2023, 03:52:00 pm »
In my archive I've this
See attached pdf
« Reply #7 on: August 02, 2023, 09:08:35 pm »
The Surfy Bear stand alone reverb is mosfet driven IIRC (it’s like a 6G15, but with fets instead of tubes). That’ll have a recovery stage. Schematic is floating around somewhere. If someone else hasn’t linked to it by the end of the day, I’ll attach the schematic file when I get back to my desktop thingy later.
« Reply #8 on: August 03, 2023, 02:52:21 am »
(Edit - attachment deleted - schematic already posted in reply #6)
« Last Edit: August 05, 2023, 01:02:57 pm by tubeswell »
« Reply #9 on: August 03, 2023, 02:58:23 am »
And the Surfy Bear (JFET)
Offline mat janssen
    • Amplifiers with valves
« Reply #10 on: August 03, 2023, 04:04:10 am »
Hi I think there is a problem in the drawing of the phase inverter. The 1M resistor shoud be connected to pin 7 of the 12AX7 and the other point of the capacitor 10nF to ground?
« Reply #11 on: August 03, 2023, 08:17:21 pm »
In reply #7? 6 Yes, there is.
Reply #6 and #8 it seems.
Typo, thanks.
« Last Edit: August 03, 2023, 10:28:08 pm by PRR »
« Reply #12 on: August 03, 2023, 08:23:29 pm »
In reply #7? Yes, there is.
« Last Edit: August 03, 2023, 08:26:23 pm by tubeswell »
« Reply #13 on: August 04, 2023, 02:12:51 pm »
Would be nice to know what type PNP Q1 is - Assuming BC556 or similar.
--Pete
« Reply #14 on: August 04, 2023, 04:08:30 pm »
"Silicon"?
It doesn't look fussy. >6V, >0.7mA, Vbe near 0.6V. You could probably put it in backward (E and C reversed) and it would play OK.
