September 26, 2026, 10:56:03 am
Hoffman Amps Forum image Author Topic: There is a female jack with additional switch to ground the exit of a gain stage  (Read 6917 times)
In reference to this schematic I would like to know if there is a female jack that used at the Organ Keyboard Input can act like intake and also have an additional switch to ground the output of the previous stage (directly or via a resistor) when a jack is inserted
THANKS
« Last Edit: August 03, 2023, 05:34:18 pm by kagliostro »
This will work...
Switchctaft 13B
Many Thanks Steve
Why do you think it needs to be shorted?
Sluckey's clever plan does what you ask but dumps the preamp signal(*) into the keyboard sleeve, which is never dead-zero impedance. A little dirt or tarnish and that unwanted signal will bleed-through.
(*)It is a guitar input? What guitarist will keep playing into an input which is muted? (Aside from Neil Young, Jorma Kaukonen, and others who can hear their guitar without sound waves.)
 :think1:   Seems to me that there is a much simpler solution. Whenever the keyboard guy plugs into the amp, he should just turn the guitar volume to zero.
Oh, I understand
As this thing is planned the Keyboard input is what will be used near always, the gutar input is only to be used very few time
The guitar input is more as an ability than a real need as the guy is not a guitarist but he asked to have one
Does someone knows the commercial reference of a female jack intake that has both a NO and a NC switch ?
Looking around I've find info and reference schematics about the existence of this kind of device but not the code of an existing item
The Fender super 60 has several (stereo) jack sockets with built in dpdt switches.
I’ve bought maybe 6 in the past, to repair a super 60, and for a couple of headphone amps I built, used to power the unit up when the input was plugged in.
Thanks pdf64
I'll try a search for Fender Super 60 input jaks
Do you have a code or a brand for such item ?
Find one that correspond
a guy gived me this indication
Arrived here I would like to know if I've draw correctly the Organ Keyboard input with the CUI SF-63043F Female Jack assuming that I want to short to ground the output of the guitar gain stage (useful or not useful it is, it is only to see if my draw is correct this way) when a Keyboard is connected to the devoted input
Will it be better to add an in series resistor that acts as a load, to the path that connect to ground the signal ?
THANKS
EDIT: Seems there is a simpler way to arrange this thing  :BangHead: :BangHead: :BangHead:
So the correct Female Jack will be the
JALCO YKB21-5076 5 Pin
« Last Edit: August 07, 2023, 07:08:15 pm by kagliostro »
A lot of trouble for a non-issue. Just turn the guitar preamp volume down. Better yet, do nothing!    :icon_biggrin:
