September 26, 2026, 08:51:33 am
Hoffman Amps Forum image Author Topic: 5e3 circuit with 500k pots?  (Read 6901 times)
Offline roseblood11
    • Layouts and Pictures
« on: August 04, 2023, 11:43:05 am »
Is is possible to use 500k log pots for volume and tone in a 5e3 build, without changing the sound and response? How would I have to change the cap values?
I`m asking, because I have to squeeze the circuit into a small chassis, where only one hole on the control panel is left. And it`s quite easy to find a 500k log dual concentric pot, but I `ve never seen 1M, at least not at a european retailer.
https://robrobinette.com/images/Guitar/5E3P_Build/5E3_Schematic_Annotated.gif
Re: 5e3 circuit with 500k pots?
« Reply #3 on: August 04, 2023, 12:05:43 pm »
He wants Log, not linear??  (So your 2nd link may be better.) (Or is that 2nd link solid-ganged instead of independent like you want for Vol and Tone in the same hole?)
And FWIW, all that crap in an eBay URL after "?hash=" is tracking YOU, we don't need it to find the same item.
https://www.ebay.com/itm/122547734789
https://www.ebay.com/itm/373006274610
« Last Edit: August 04, 2023, 12:08:19 pm by PRR »
Offline roseblood11
« Reply #4 on: August 04, 2023, 12:11:11 pm »
Thx... But the seller doesn`t ship to Europe.
Would it be possible to get away with 500k log?
« Last Edit: August 04, 2023, 12:13:29 pm by roseblood11 »
Offline Dave
« Reply #5 on: August 04, 2023, 12:13:58 pm »
Possible, yes. Probable, yes. Will it change the response, yes. Will it matter, that's up to you to decide.
Dave
Offline ac427v
« Reply #6 on: August 07, 2023, 08:00:07 am »
I considered 500ka pots as a way to get finer control in low volume situations. With the standard 1M pots there is a big jump between a 1.1 setting and a 1.2 setting. I never tried it. Sorry. I eventually went to a modified 1 stage 6G3 preamp and am happy with that. But recently I saw the DeArmand and Martin circuits using 350ka pots. I wonder how they sound?
Offline roseblood11
« Reply #7 on: August 07, 2023, 08:21:15 am »
The online version of the old Duncan tone stack calculator has a model of the Princeton 5f2-a.
I can get a very similar frequency response with 1M or 500k pots, but at different levels. Which might be no problem, as I'll have to use a 12ax7 instead of 12ay7 as the first gain stage anyway.
My goal isn't a perfect copy of any of the old Fender circuits.
I'm working on a Vox AC30 clone with three channels. CH1 is the stock top boost channel. But CH2 will be the Fender brownface harmonic tremolo instead of the Vox vib/trem channel - 7 triodes instead of 6. That means, that I need one more tube anyway, and I decided to add a CH3 with the Fender 5e3 preamp topology, instead of the Vox normal channel. So, the 5e3 preamp goes into a LTP phase inverter, the EL84 power amp and a 1*12 + 1*10 combo. Very different from a Tweed Deluxe anyway...
https://www.guitarscience.net/tsc/princeton.htm#RIN=38k&RT=1M&RV=1M&RL=1M&C1=22n&C2=4.7n&C3=500p&RT_pot=LogA&RV_pot=LogA
« Last Edit: August 07, 2023, 08:33:11 am by roseblood11 »
