September 26, 2026, 03:19:34 am
Hoffman Amps Forum image Author Topic: power supply bias design  (Read 5438 times)
Offline fossilshark
  • No life til' leather
« on: August 04, 2023, 08:21:06 pm »
Hi all, went to order parts to design the power supply PCB and realized the transformer I plan on using does not have a 50v CT (Hammond 273BX). The 700v center tapped HT line is rated for 201ma, could I throw a resistor on the 700v line (or divider between the 350v line and GND) to get 50V? How would I calculate the value(s) needed?
This is for a 100w amp meant to be able to use 6l6 or el34.
I greatly appreciate any advice!
~SNOWBLIND~
Offline Dave
Re: power supply bias design
« Reply #1 on: August 04, 2023, 08:41:54 pm »
You can use one leg of the secondaries. Look at just about any Marshall schematic. That's how they did it.
Dave
Offline fossilshark
« Reply #2 on: August 04, 2023, 09:01:01 pm »
Looking at 100w jcm800 schematics it seems that marshall uses 350vac instead of 700vac center tapped, would I just double the values of the resistors and pot to get around where id need to be?
How much current could I expect the bias of an EL34 and 6L6 to draw at 100w? I would be able to use that to calculate the voltage divider needed more accurately.
~SNOWBLIND~
« Reply #3 on: August 04, 2023, 10:02:39 pm »
Bad example! Do it like this...
     http://sluckeyamps.com/phoenix/phoenix.pdf
Offline fossilshark
« Reply #4 on: August 04, 2023, 11:03:01 pm »
perfect thank you!
~SNOWBLIND~
