September 20, 2026, 02:24:22 am
Hoffman Amps Forum image Author Topic: Easiest Circuit with The Fewest Parts  (Read 19643 times)
Offline imgumby001
« on: August 06, 2023, 02:13:12 pm »
Hey everyone!! What would be some circuits that are super simple and have the least amount of parts? I’m bored and looking for a build while my fam is out of town. I’ve already built a couple 5f1’s and a 5e3, so it would be great to build a different simple circuit from those.
Thanks all!!
NR
Offline Dave
Re: Easiest Circuit with The Fewest Parts
« Reply #1 on: August 06, 2023, 02:20:01 pm »
That's an interesting question. Personally, I have never done it. I start with the most complex and work my way down. I'd kind of like to build a dead simple amp someday. Hopefully, I'll live that long.
Dave
« Reply #2 on: August 06, 2023, 02:24:04 pm »
This is the simplest amp I have. Chassis may be hard to come by. But just imagine the look on their faces when your family comes home and tries to heat up a bagel?   :l2:
     http://sluckeyamps.com/smoky/smoky.htm
Offline AlNewman
« Reply #3 on: August 06, 2023, 02:48:37 pm »
That gain control looks pretty cool.  Does it work well?
« Reply #4 on: August 06, 2023, 02:55:36 pm »
Yes. Useful tone/gain change.
Offline AlNewman
« Reply #5 on: August 06, 2023, 04:24:55 pm »
Yeah, looks neat.  Probably lots of ways to experiment with different values to dial in a certain sweep.
Offline Loomer
« Reply #6 on: August 06, 2023, 05:11:35 pm »
Not quite the simplest with a whopping 3 tubes, but the vibro champ would give you a lot of amp for not a lot of components, even more so if ditching the tremolo, which would make it a two-tuber.
Offline imgumby001
« Reply #7 on: August 06, 2023, 07:39:53 pm »
Steve, that is so cool I almost can’t breathe. I should have figured one of your designs would be added to my “next” list!! Now I gotta find a toaster!!!!
Offline imgumby001
« Reply #8 on: August 06, 2023, 07:43:47 pm »
It’s not a bad suggestion, I just have a 5f1 I like a lot, and I built a Weber revibe, so I kind of have all that already. Not that a straight fender circuit is EVER a bad thing, I’ve just built several at this point and I’m itchin to get into someone else’s designs. I definitely have all the parts for a Princeton, but I’ve got a LOT of parts for whatever as well!!!! That being said what I don’t have are board blanks. So I’m gonna have to build on strips, hence the “few components” thing.
Offline passaloutre
« Reply #9 on: August 07, 2023, 01:13:45 am »
Well you’ve already built the two I would have suggested. If you wanted to go bigger, but still sparse, I might suggest something like a Thunderbolt. No parts wasted there, well except that extra triode…
« Reply #10 on: August 07, 2023, 02:56:48 am »
Did a clone of this one
Rex Mascot (el34world.com)
Offline imgumby001
« Reply #11 on: August 07, 2023, 06:48:13 am »
I’ll look into this. Thanks bubba!!!
Offline imgumby001
« Reply #12 on: August 07, 2023, 06:48:53 am »
Now this is very intriguing!!! Thanks boss!!!
Offline roseblood11
    • Layouts and Pictures
« Reply #13 on: August 07, 2023, 08:28:33 am »
Read the build documents for the kits from Tube-Town . de. They have some interesting circuits.
https://www.tube-town.net/ttstore/bausaetze/amps/
Or the Madamp G3 (Rock or Blues versions), which was a forum project at the german musikding . rocks forum. It's a cheap build, as it's based on old russian tubes.
Offline dude
« Reply #14 on: August 07, 2023, 10:37:59 am »
How about Sluckey's PeeWee, no board needed, just drill a socket for a 12Ax7 and have a "Mini Twin", just need an AO44 Hammond chassis off ebay for $50, get one with tubes and you're almost done.
https://sluckeyamps.com/PeeWee/peewee.htm
Offline imgumby001
« Reply #15 on: August 07, 2023, 01:25:33 pm »
I really like both those sites. I’ll have to look, but I think I actually have a couple 6n2p’s floating around…
Offline imgumby001
« Reply #16 on: August 07, 2023, 01:27:12 pm »
This is actually a great option, and I may just have an ao44 left intact. I know I have the iron and an empty chassis, I just saw them yesterday!
Offline dude
« Reply #17 on: August 07, 2023, 01:59:47 pm »
The PeeWee sounds like a baby Fender twin, an amp tone you don’t have.
« Reply #18 on: August 07, 2023, 02:15:15 pm »
If you like the idea of the peewee but rather have a vox sound just steal the EF86 preamp from my Vox AC-15 lite.
     http://sluckeyamps.com/hammond/hammond.htm
« Reply #19 on: August 07, 2023, 03:09:08 pm »
As to go with less components, if your choice is an amp with a Tube Rectifier, just swap it for a Solid State rectifier and you'll have a less tube amp without effort
« Last Edit: August 07, 2023, 03:16:01 pm by kagliostro »
Offline mmack
« Reply #20 on: August 07, 2023, 05:43:47 pm »
D-Lab Electronics on youtube has a 2 watt amp based on 6CL6. Schematic looks fairly simple although not sure how much simpler it is over a champ.. he claims it only costs ~$5 in parts. Not sure how good it sounds, I doubt it would be better than a champ although probably less volume.
The bassman micro from Rob Robinette seems really cool. Probably a little more complicated than you're looking for though.
« Reply #21 on: August 07, 2023, 05:56:43 pm »
I'm a big fan of the Smoky amp by our friend Steve
Very simple and different from "standard"
Obviously you are not obliged to find an Oven to put it on it  :wink:
May be this kind of Box will be easier to be find to be used as an unusual Cabinet
« Last Edit: August 07, 2023, 06:12:59 pm by kagliostro »
Offline bmccowan
  • Better builder than player
« Reply #22 on: August 08, 2023, 07:24:43 am »
A few ideas - although I think the Smokey is a fine idea and I recall the discussion around Steve deciding on the circuit. That thread would be worth digging up.
 - Single ended octal - There is the earlier 5C1 Champ. But also Gibson and Valco versions. I built a Valco/Supro 6SL7 > 6V6 that is sweet and have a Valco that was private labelled for a music store/school that has a 6SJ7 preamp - similar to the 5C1.
 - 6BM8 amps. I love that tube. Lots of options. For SE you could look at the version of the Gibson GA-5T that uses that tube and delete the trem. Or simply go with the a one tube design using the triode and pentode of that tube. For P-P it'd be hard to beat a version of the mini-bassman/little wing or HoSo that use a pair of those. And you have Tubenit's experience to lean on.
 - Gibson simple P-P - BR6F I love the tone of this amp - just a volume pot.
 - Gibsonette - pretty much a Champ circuit with parallel 6V6 output. There are a few versions of this amp.
Mac
John Prine
Offline Platefire
« Reply #23 on: August 08, 2023, 12:34:19 pm »
First time I've read the story of Smokey. What a great history and fine re-purposing project. :bravo1: What was your wife's comments on that and was that really your last amp?
I've always had thoughts of building the smallest amp possible
On the right track now<><
Offline JPK
« Reply #24 on: August 08, 2023, 01:21:57 pm »
This is a cool thread. I need ideas for this winter. That Pee Wee with ac15 pre is looking good. Toaster is awesome. I actually have an old metal toaster. May need to look at that closer when I get home.
I love tubes
« Reply #25 on: August 08, 2023, 02:56:55 pm »
She said "where you gonna put that?" as she rolled her eyes.   :rolleyes:  She doesn't share my enthusiasm for "just one more amp".   :icon_biggrin:
That should have been my last amp but then shooter messed me up by returning my old Plexi 6V6 chassis. So the Phoenix became my last amp.
« Reply #26 on: August 08, 2023, 03:06:30 pm »
Vox AC-4 could be another candidate...
     https://sluckeyamps.com/misc/VAC-4.pdf
« Reply #27 on: August 08, 2023, 03:54:50 pm »
blame away  :laugh:
here's my 2C worth amp, do SS rec and 1 EL84 for a 2 tube screamer.  ( not the final version, so some tweaks maybe required)
Offline Platefire
« Reply #28 on: August 08, 2023, 05:02:31 pm »
That's what I was thinking looking at sluckey's AC-4. Remove the Trem circuit and use a SS Rec and you could pretty drastically reduce parts and space required
This is my Little Bear amp:
« Last Edit: August 08, 2023, 05:09:46 pm by Platefire »
« Reply #29 on: August 08, 2023, 05:18:38 pm »
I'm still blocked on the Smokey with my preference
but if you want less part ........ One Tube Amp .....
https://zeppelindesignlabs.com/product/percolator-2w-amp-kit/
you can find documentation as to build it without the kit
https://www.zeppelindesignlabs.com/wp-content/uploads/docs/Zeppelin_Perc_ASSEMBLY%20INSTRUCTIONS.pdf
https://music-electronics-forum.com/forum/schematic-requests/52075-?t=50811
OT is around 6K primary - B+ is around 175V
« Last Edit: August 08, 2023, 05:34:05 pm by kagliostro »
« Reply #30 on: August 08, 2023, 05:53:01 pm »
Your part count is as high as the previous 2 amps combined
EDIT:  Your cab looks better though  :laugh:
« Last Edit: August 08, 2023, 05:55:49 pm by shooter »
« Reply #31 on: August 08, 2023, 05:59:33 pm »
OK, you want the war  :laugh:
PRR Third watt amp
« Last Edit: August 08, 2023, 06:06:47 pm by kagliostro »
« Reply #32 on: August 08, 2023, 07:23:47 pm »
The pot and cap on the screen grid of the output tube in the Nov '07 plan can be omitted for "fewest parts" use.
« Last Edit: August 09, 2023, 12:29:31 am by PRR »
Offline Platefire
« Reply #33 on: August 08, 2023, 10:33:55 pm »
« Last Edit: August 08, 2023, 10:41:23 pm by Platefire »
« Reply #34 on: August 09, 2023, 10:15:27 am »
When you remove the trem on the AC-4 it starts to look a lot like Smoky. Remove the gain and tone for a simple one knobber.
Offline Platefire
« Reply #35 on: August 09, 2023, 01:33:52 pm »
Yelp, that's narrowing it down to the bare necessities. I guess we got carried away :dontknow: we lost imgumby001 somewhere along the way
« Last Edit: August 11, 2023, 12:40:44 am by Platefire »
« Reply #36 on: August 09, 2023, 03:03:10 pm »
Less of this I think is difficult
Gibson Mastertone Special
Gibson Les Paul
Gibson Les Paul JR
consider no Field Coil (use a resistor) and no Tube Rectifier (use Solid State Rectifier)
Offline imgumby001
« Reply #37 on: August 22, 2023, 12:13:51 pm »
No, no bubba, I’m still here!!! And may I say a HUGE thanks to everyone who has contributed to this thread! You all have come through in the way I have come to expect from the members of this forum, all hands on deck style. The problem iiiissssss…
…now I want to build ALL of these circuits!!!!
Offline Platefire
« Reply #38 on: August 22, 2023, 03:19:46 pm »
Hay imgumby001  Glad your pleased and welcome back.
I want to throw in another circuit that I built from a Revere Reel to Reel amp that I'm amazed at how loud and clean it can get in boost mode for a SE EL 84 amp. It uses a SPDT Center off switch to give you three amp modes, adjustable Negative feeback, Normal(center off) and Boost with cathode bypass cap on the second preamp gain stage. I used the reel to reel's transformers, so I have no recommendations on that. Champ types would be my best guess
« Last Edit: August 22, 2023, 03:30:59 pm by Platefire »
Offline imgumby001
« Reply #39 on: August 23, 2023, 01:05:24 pm »
It’s funny that you mention transformers at the end of your post. Yesterday after I read through all the entries in this thread, I pulled out all my available iron. I then realized that should have been the first thing I did!!! All my PT’s waaayyyy overkill. I’ve got plenty of pp and se OT options, but man, I don’t have a single PT pushing less than 340-0-340. I’m starting to think I’d be better off trying to build a super twin instead!!!
Offline imgumby001
« Reply #40 on: August 25, 2023, 09:55:13 am »
After much consideration I’m thinkin I gotta build Slucky’s Smokey. It’s just too perfectly laid out for me!!! I’ve got about half the cheap parts already, just have to find affordable transformers!!!
Thanks to everyone who contributed to this thread!!!
Offline Platefire
« Reply #41 on: August 25, 2023, 01:44:09 pm »
That looks like a good minimal amp. I'm just not familiar with those tubes. I figure they are a cheaper substitute for the original AC4 type?
Offline imgumby001
« Reply #42 on: August 26, 2023, 09:14:39 am »
I’m not really either, but that’s part of the fun!!! I really like the little bear, it looks like a really cool circuit. I’ve even got a bunch of the parts. The Smokey just looks so clean, not that I can get it that way, but ya. I still my try the little bear in the near future. I put a couple “extra” small chassis in my cart just in case I NEED them!!
« Reply #43 on: August 26, 2023, 10:52:47 am »
Both of those tubes are 7-pin. The 5654/6AK5 was used extensively in old military/FAA radar receivers, mainly as a 30MHz IF amplifier. They're very reliable, low noise, and can be used in audio circuits as well as RF/IF circuits up to about 400MHz. Works very well in an EF86 circuit. The 6005/6AQ5 is kinda a 6V6 in a small bottle. It cannot take a high voltage like the 6V6 though.
Both tubes are pretty cheap and readily available. May not stay that way if word gets out about these tubes.  :icon_biggrin:
Offline Platefire
« Reply #44 on: August 26, 2023, 11:31:48 am »
Thanks sluckey for the explanation on those tubes. All my old builds and store bought amps are tuned up and working great. I'm starting to ponder, what's next? I kinda miss the trouble shooting and amp repair but I found that is pretty stressful, so I don't want to go there again.I have a Fender Excelsior OT, so I reckon that's a good place to start :think1:
Offline imgumby001
« Reply #45 on: August 26, 2023, 02:51:05 pm »
I’ve actually got a couple 6aq5’s that I had no idea what to do with. They’re actually nos still in the box. The 6ak I’ll have to source. Already have the 7 pin sockets in my cart!!! If you had to buy transformers new do you know which ones you’d choose?
« Reply #46 on: August 26, 2023, 04:20:11 pm »
I'd use Hammond 269EX for PT and Hammond 125BSE for output.
Offline imgumby001
« Reply #47 on: August 26, 2023, 05:49:33 pm »
Thanks boss!! I’m really looking forward to this. I’m thinkn I’m gonna whet my appetite with the Smokey and once it’s right, and fully functional, I’m gonna tackle the dual lite!!!
Offline Greenwichpaul
  • I love valve amps
« Reply #48 on: August 29, 2023, 07:19:57 am »
Hmmm. I just located a 5k/8ohm Carnforth OT, plus a 250V secondary toroid (over 100mA I'm certain) in my surplus box. I really fancy trying a Vox again. I am thinking the Carnforth should suit the EL84 - and the 250V would work with a diode bridge plus circa 1k dropping resistor for the AC-4. Does that logic seem sound?
« Reply #49 on: August 29, 2023, 08:18:48 am »
Sounds good to me. There's an AC-4 layout on my website that may give you some ideas.
