September 26, 2026, 11:46:00 am
Hoffman Amps Forum image Author Topic: Measuring V+(plate voltage)  (Read 6929 times)
Offline Champ_49
« on: August 07, 2023, 02:39:37 pm »
I hope I posted this on the right thread. I apologize if not. I'm still confused what plate voltage is. Let me explain what I mean.  This is to bias the tubes. On the web you would need this value to calculate the current draw to bias the power tubes at let's say 70% of max plate dissapation.
My question is when you bias the tubes or current draw it CHANGES the plate voltage. So the plate voltage is not a constant value but VARIES. So what exactly is the plate voltage that you use to calculate the bias current draw?? I apologize for the dumb question if it is a dumb question.
Re: Measuring V+(plate voltage)
« Reply #1 on: August 07, 2023, 02:46:43 pm »
It varies a little. NOT a lot. Unless your power supply is lame.
Get some numbers from a trial bias. Adjust. Check. One or two rounds should be plenty close.
Offline Champ_49
« Reply #2 on: August 07, 2023, 04:17:57 pm »
This is what I measured. I have put in seperate bias pots for each tube. Roughly the current draws are as follows and the plate voltage that corresponds to that current draw for each tube.
14mA - 471V
15.8mA - 468V
26mA - 461V
41.5mA - 451V
55mA - 443V
From 14mA to 55mA that is a 28V difference. Would this be considered alot? Or negligible in this case.
Offline Esquirefreak
« Reply #3 on: August 07, 2023, 04:35:12 pm »
Isn't the whole point of each tube having a dedicated bias pot to balance the bias? Or why else would you do it that way?
/Max
« Reply #4 on: August 07, 2023, 04:39:00 pm »
take those #'s and do some math to get Watts, you should see a correlation.
all that goes out the window when you start jammin some heavy medal, followed by lounge music, followed by.....
if you have 1 ohm resistors cathode to ground on the power tube(s) you can "monitor" the real-time effects of the AC signal effecting the DC characteristics
« Reply #5 on: August 07, 2023, 04:46:06 pm »
I would consider that typical, nothing to get up about.
Offline Champ_49
« Reply #6 on: August 07, 2023, 04:48:34 pm »
Yes. I have 1ohm resistors to ground and then to test points.  I've seen the fluctuations with the multimeter when injecting an AC from the guitar. When I first saw it the readings on the multimeter jumped quite high. Freaked me out a bit but realized it's normal and it's AC so there are lows and high peaks which balance out.
What matters would be the bias at idle.
« Last Edit: August 07, 2023, 04:56:51 pm by Champ_49 »
« Reply #7 on: August 07, 2023, 06:46:08 pm »
In my world we had Peak power and Average power.  I could get 25Kw of peak power with an average power of 500W.
Time is the factor to consider, duty cycle.  So a long hard note feeding back through the speaker is gonna make the tube work overtime, where a quick pick note that's hand muted will let the tube lounge around n cool off.
« Reply #8 on: August 07, 2023, 07:37:28 pm »
Now give him the formula to convert peak power to average power and express in dbm.    :icon_biggrin:
« Reply #9 on: August 08, 2023, 03:52:34 am »
 :l2:
it's 5am
