September 19, 2026, 11:10:41 pm
Hoffman Amps Forum image Author Topic: Help with Power Transformer voltages?  (Read 5218 times)
Offline mini612
« on: August 30, 2023, 02:06:52 pm »
To Admin ***I hope I'm in the right thread, if not, please move this or cancel it and I can post it in the right place***
I bought a box of misc old radio parts a few years back and this past weekend I dug through it to look for a PT for my new project.  Unfortunately, there was only one PT in the whole box!  It's physically smaller than the other PTs I have.  The PT has two black leads for primary, and secondary consist of two Red leads (no CT) and two Greens.  I decided to test it to at least know the values of the leads and the result is; Red leads = 172vac., and Green = 6.5vac.  I decided to to see if I could raise up the voltage a bit by using a full bridge rectifier with four 1n4007, and I got 156vdc.  I was a bit disappointed.  Without knowing any additional details of this PT, can someone tell me why I got 156vdc instead of something a little higher?
« Last Edit: August 30, 2023, 02:18:34 pm by mini612 »
Re: Help with Power Transformer voltages?
« Reply #1 on: August 30, 2023, 02:29:12 pm »
Put a filter cap across the bridge and the unloaded voltage will increase to 240VDC.
Offline mini612
« Reply #2 on: August 30, 2023, 02:45:52 pm »
OH YES!  Got it.  Thank you.
