September 20, 2026, 08:13:36 am
Hoffman Amps Forum image Author Topic: 5W Single Ended Dual Lite? Tweed/Vox  (Read 6813 times)
Offline BrainDeadAmps
  • Trial and error
« on: September 20, 2023, 11:50:30 am »
I purchased a lot of those 5 watt Akai m8 amps at an estate sale last year and am finally getting around to rebuilding them into guitar amps. For those unfamiliar they come with shock-mounted ef86 and 12AX7 pre-amp sockets and a el84 power tube. I have never built an amp with dual pre-amps and I am looking for some suggestions on the best way to implement it into this conversion project. I have a basic mock-up attached with tweed tone controls modified for less interaction on both channels with two 220k resisitors feeding the driver stage.
For a clean look I would like to use dual ganged pots for both the vol and tone pots,I noticed in sluckey's dual lite he used 500k pots instead of 1M, perhaps I would benefit from lowering my values to 500k also? like the 18watt trem channel.
Re: 5W Single Ended Dual Lite? Tweed/Vox
« Reply #1 on: September 20, 2023, 12:16:36 pm »
When you finished your dual channel, as you say you have more than one to convert, if I can suggest (from our friend Dwinstonwood)
https://el34world.com/Forum/index.php?action=dlattach;topic=27512.0;attach=107694
« Reply #2 on: September 20, 2023, 12:23:17 pm »
1M volume pots should work just fine.
  • Trial and error
« Reply #3 on: September 20, 2023, 12:58:15 pm »
Thanks guys, I like the idea of a simple treble cut on the ef86 side. Will report back when I get it Built.
« Reply #4 on: September 20, 2023, 01:42:11 pm »
Usually pentodes don't like to feed Tone Controls because they are a high load for them
Very difficult to see an amp with a tone control different from a rotary switch swapping different caps that follows a pentode (see Sluckey dual lite)
One of the few examples of amp that has a tone control following a pentode is the Dr Z Route 66
« Last Edit: September 20, 2023, 01:45:20 pm by kagliostro »
« Reply #5 on: September 20, 2023, 02:30:28 pm »
Whoever drew that Dr Z schematic really botched the bias supply!
« Reply #6 on: September 20, 2023, 03:58:04 pm »
Seems that a cap is missing
« Reply #7 on: September 20, 2023, 04:51:03 pm »
Yes. A cap and a resistor, and the filter caps are backwards. The Route 66 schematics I've seen did not use a bridge rectifier.
  • Trial and error
« Reply #8 on: September 20, 2023, 09:44:26 pm »
Still playing with ideas, what Franco said kept coming back to mind because I've read that same notion in countless old threads i've gone through regarding the use of pentodes. I'd like to avoid the monstrous 6 position rotary switch and sub a 2-way mini switch instead to select different coupling caps. I haven't stumbled upon any examples of a simplified version. I have two mock up examples, what would be the best way to implement this?
« Reply #9 on: September 21, 2023, 12:47:15 am »
Ciao BrainDeadAmps
Looking to your initial attempt to a Tone Control for the EF86 I remembered that it can work correctly with only a bit of adjustment
The Rotary Cap Selector can be swap with a pair of capacitors and a pot
Mr. Merlin suggested this thing
« Last Edit: September 21, 2023, 03:00:58 am by kagliostro »
