September 15, 2026, 12:07:09 pm
Hoffman Amps Forum image Author Topic: plate fed tonestack master  (Read 6115 times)
Offline joesatch
  • save me from myself.
« on: October 14, 2023, 10:00:34 pm »
master placement difference between these two?  (imo nothing but not sure)
Re: plate fed tonestack master
« Reply #1 on: October 14, 2023, 11:45:19 pm »
Tonestack usually likes to be fed from a low-ish impedance. Not the center of a 1Meg pot.
But it is just a couple wires to try it one way then another. Don't overthink too much.
Online sluckey
« Reply #2 on: October 15, 2023, 05:39:55 am »
I've never seen a C6 in that tone stack.
« Reply #3 on: October 15, 2023, 06:23:55 am »
Some people advocate putting the master before the tonestack, Jose style.
In theory it seems a retrograde move but I’ve not bothered to try it yet, so  :dontknow:
With regard to the right hand drawing, the DC blocking cap C8 seems redundant? Whatever, it’s in series with C11 the bass cap, and as they’re the same value, the effective valve of the bass cap will be halved.
And yes, the capacitive reactance of C6 and C9 the treble cap will form a high frequency potential divider / low pass filter.
Which end of the treble pot is intended to be the most trebly? Have you tried this?
« Reply #4 on: October 15, 2023, 02:55:57 pm »
I've seen something *like* that in one of the recent amps that nobody loves.
Offline joesatch
« Reply #5 on: October 16, 2023, 09:56:24 am »
i tested values here. it removes some of the ice pick spikyness off the highs. Probably could be placed elsewhere
Offline joesatch
« Reply #6 on: October 16, 2023, 09:58:23 am »
dont know why C8 is there myself. would be necessary in the left drawing but not the right
Offline nworbetan
« Reply #7 on: October 16, 2023, 11:12:06 am »
Most commonly placed as a bypass cap across the preceding anode resistor.
Offline nworbetan
« Reply #8 on: October 16, 2023, 11:19:45 am »
My best guess is C8 is intended to be located close to the valve to keep the high DC voltage away from the tone controls on the "other side" of the chassis.
