September 16, 2026, 06:19:42 pm
Hoffman Amps Forum image Author Topic: Dropping the 60v bias tap to create 5v to facilitate tube rectification?  (Read 5563 times)
Offline Duncan
  • I used to play guitar.
Howdy.
I’ve got a gutted Traynor YBA-1 that I’m looking to build into a Matchless Chieftain type circuit.
The only components remaining from the Traynor are the transformers and pilot light. The only thing is that the power transformer (Hammond 291JX equivalent) doesn’t have a 5v tap. It DOES have a 60v tap however.
According to some numbers I crunched, I could pass this 60v through a pair of 2.7k 2w resistors (one for each side of the winding) to get me 5v.
Does this sound like it would work?
Re: Dropping the 60v bias tap to create 5v to facilitate tube rectification?
« Reply #1 on: November 11, 2023, 10:48:42 am »
No. That 60V winding is only rated for 20mA.
Offline Duncan
« Reply #2 on: November 11, 2023, 12:24:49 pm »
Well dang. You’re right. We’ll nevermind on that idea.
Looks like it’s the diode life for me!
« Reply #3 on: November 11, 2023, 12:29:02 pm »
What Sluckey say
You don't need a tube rectifier, use Solid State rectify and a SAG resistor
« Reply #4 on: November 11, 2023, 12:58:04 pm »
A rectifier heater winding is not a TAP, it is an isolated winding. It sets 400 Volts away from circuit common.
Bias 'taps' usually ARE taps connected to HV common (actually just the first 500 turns on one side of the HV CT).
« Reply #5 on: November 11, 2023, 01:01:15 pm »
The 291JX has a real separate 60V winding, not a tap on the HT winding.
