September 16, 2026, 12:44:16 pm
Hoffman Amps Forum image Author Topic: From Mono to Pseudo Stereo - does it exist a Tube circuit that do that ?  (Read 7459 times)
Some years ago I assembled a Solid State (IC based) Theremin Kit
that Kit had a "Stereo" output, the mono signal was processed using a TDA 3810 IC that gives a Pseudo Stereo output
I would like to know if there is a Tube circuit that can obtain the same result and, if it exist I'm interested to a schematic
p.s.: Note that I've no idea to which is the process applied to the signal to enter Mono end exit Pseudo Stereo
« Last Edit: December 06, 2023, 07:12:00 am by kagliostro »
Re: From Mono to Pseudo Stereo - does it exist a Tube circuit that do that ?
« Reply #1 on: December 06, 2023, 07:39:20 am »
the "basics" would be,  stereo jack signal in(L R signal), mix R's at input jack to "mono", amplify, then split signal for "left", "right", speaker.
each speaker will output a "stereo" signal (L R mixed).
Offline acheld
« Reply #2 on: December 06, 2023, 10:17:35 am »
I was reading this the other day, it gives some ideas about how pseudo stereo is implemented:  https://www.soundbridge.io/pseudo-stereo-effect
My current rig uses two amps, with a signal splitter --> amp one is dry signal only, amp two gets the pedals.
I would love to use the stereo effects in some of my pedals, but honestly it is a pain to do with more than one pedal in the chain.
« Reply #3 on: December 06, 2023, 08:58:49 pm »
If you can possibly find that kit, or any similar fake-stereo kit, or do it with opamp chips, don't fool with tubes. The impedances and gains are semi-critical and a good inverter in tubes is two triodes at least. Find your "tube flavor" somewhere else in the system.
Start with the TDA3810: https://pdf1.alldatasheet.com/datasheet-pdf/download/19305/PHILIPS/TDA3810.html
Work out the internal and external circuits. The signal goes through and back again. There's a mix/difference network and a twin-Tee filter, all switchable and criss-cross. It might makes sense if re-drawn one mode at a time.
« Reply #4 on: December 06, 2023, 11:23:47 pm »
The Signetics datasheet with filter curves:
www.elektronikjk.com/elementy_czynne/IC/TDA3810-2.pdf
Apparent error in most schematics:
http://www.geocities.ws/podernixie/audio/tda3810-en.html
"pins 3 and 5 must be swapped."
Simplified project:
https://www.aaroncake.net/circuits/stereosynth.asp?showcomments=all
archived: https://web.archive.org/web/20130522015802/https://www.aaroncake.net/circuits/stereosynth.asp
"FULL" 1987 Signetics chip datasheets, >1000 pages
http://www.bitsavers.org/components/signetics/_dataBooks/1988_Signetics_Linear_Data_Manual_Vol_1_Communications.pdf
I think TDA3810-pins-3-5-fix.gif has the right connection at pins 3 and 5?
« Last Edit: December 06, 2023, 11:41:18 pm by PRR »
« Reply #6 on: December 07, 2023, 01:27:26 am »
Many Thanks to ALL
@ PRR
Thanks for the link, I'll read with interest, the theory about is unknown to me
Offline Bash
  • Tu be or not tu be
« Reply #7 on: December 09, 2023, 05:43:15 am »
Using a mono amp with two completely different speakers might do the trick.
Or add a bucket brigade circuit that slightly delays one of the signals.
« Last Edit: December 09, 2023, 05:45:25 am by Bash »
« Reply #8 on: December 09, 2023, 06:22:56 am »
Ciao Bash
My question is related to something I didn't specified
The input, as understandable, will be a single mono signal from a guitar buth then it will be followed by a stereo amp
Offline Bash
« Reply #9 on: December 09, 2023, 08:38:24 am »
In that case I'd just add a mono-out/stereo-in fx loop.
« Reply #10 on: December 09, 2023, 09:07:29 am »
.... mono-out/stereo-in ....
 :w2:   :w2:   :w2:
Offline Greenwichpaul
  • I love valve amps
« Reply #11 on: December 10, 2023, 07:59:51 am »
as far as I know (i hope someone will correct me if I'm wrong) the 3810 uses simple comb filtering; so some frequencies are emphasised in one channel, and the other channel does the converse.
I think if I were doing it, I'd use the Fender harmonic trem design, and send the two outputs to each side of the stereo amp.. You won't get a straightforward trem if the speakers are distant from each other; ie the phase cancellation will be less, but it will add harmonic and phase complexity to the resulting sound field, with the trem set on a slow speed.
Alternatively, something like the magnatone stereo vibrato, on a low setting, would give a more complex stereo sound.
Hope I've understood the question, forgive me if not.
« Reply #12 on: December 11, 2023, 12:57:21 am »
...i hope someone will correct me if I'm wrong...
I read the links linked above, and if that is a comb, it is a one-tooth comb.
