August 07, 2026, 06:45:22 pm
Hoffman Amps Forum image Author Topic: Tube effects loop question  (Read 4289 times)
Offline audiosalvage
« on: December 31, 2023, 09:01:00 pm »
Hey folks,  I'm building a Merlin design tube effects loop, and wondering if shielded wire is required.  Thank you
Offline d95err
Re: Tube effects loop question
« Reply #1 on: December 31, 2023, 11:13:24 pm »
For which wires?
« Reply #2 on: December 31, 2023, 11:15:37 pm »
in and out, send and return
Offline d95err
« Reply #3 on: January 01, 2024, 05:44:53 am »
It's certainly not required. Since the loop is late in the signal chain, noise usually isn't much of an issue.
If the layout has long wires (e.g. from send/return level controls on the front panel to/from jacks at the back) I would probably use shielded wire. If everything is near the back I wouldn't bother with shielding.
Offline Ronquest
« Reply #4 on: January 01, 2024, 07:42:13 am »
If you have some distance to go with the wires, better shield them.  That return gain stage is a (hi gain) stage.  No sense in not using shielded wire IMO.  I always do.
I've used Merlin's series loop many times, it's great with just a patch cable in the loop and using the loop's send volume to cut gain and drive the prior gain stages  and the loop's cathode follower harder before the master volume.  Some different over driven tones there worth trying out.
Offline JPK
« Reply #5 on: January 02, 2024, 08:51:42 am »
Yep shield. Unless it's just an inch or two. Anything over that, I would. In my last one the send came from the board to the send jack (6-8 inches). That was shielded. Return went directly from the return jack to the tube socket via 0.1uF cap so no shield (note: forgot to shrink tube the shield drain and didn't want to re-do it, oh the OCD  :help: ).
« Last Edit: January 02, 2024, 09:02:50 am by JPK »
I love tubes
