August 06, 2026, 05:34:00 am
Hoffman Amps Forum image Author Topic: Harmony 420 Need some advice/help again please  (Read 8134 times)
Offline Show Me Guitars
« on: January 02, 2024, 04:24:10 pm »
Hi everyone, I am looking for a new power transformer for a Harmony H420.
 I ordered one but it's not correct even though the manufacture assured me it was.
Last advice helped me finish a Kalamzoo Reverb 12 which came out stellar, much appreciated everybody!!
Re: Harmony 420 Need some advice/help again please
« Reply #1 on: January 02, 2024, 05:49:27 pm »
That's not enough info to even make a wild ass guess! What transformer did you order? Show link to spec sheet. Why do you say it's not correct?
BTW, there is a dangerous error on the schematic, possibly a PT killer.
Offline Latole
« Reply #2 on: January 03, 2024, 04:25:26 am »
You are right
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #3 on: January 03, 2024, 05:29:47 pm »
this might be better (haven't done a complete comparison)
https://www.angelfire.com/mech/beansamps/supro/harmony420.html
Might be a good idea to fix the schematic library, or at least add a footnote
I'll bet the dot should be a jump over
« Reply #4 on: January 03, 2024, 05:55:27 pm »
Both of those dots should be a jump over. That's not the fatal error I see.
Offline scstill
    • Still Amp'd
« Reply #5 on: January 03, 2024, 07:01:47 pm »
I rarely (never) use full wave bridge ss diodes for rectification
But the ones I've seen do not have a HV center tap
« Reply #6 on: January 03, 2024, 07:25:33 pm »
Yep. As drawn those two diodes that are connected to ground will fail in about 1/60 second. Hopefully they will just blow apart. Otherwise, the PT will be in trouble.
Offline Latole
« Reply #7 on: January 04, 2024, 03:20:18 am »
« Reply #8 on: January 04, 2024, 10:38:34 am »
Hi All, I was told a Hammond 290PAZ would work, not really close.
This amp is the same circuit a Supro Thunderbolt.
I was hoping someone may have had done this replacement before. thx
« Reply #9 on: January 04, 2024, 02:30:15 pm »
The amp is nothing special. That 290PAZ will work just fine if it will physically fit the chassis (or you can make it fit). But you cannot use a bridge rectifier with the 290PAZ. Most anyone can handle this simple task.
Offline scstill
    • Still Amp'd
« Reply #10 on: January 04, 2024, 07:21:06 pm »
Seems that the 290PAZ has a lot more windings than you need so might cost a bit more (see HawkUSA.com)
Check out this site, section called "Spare Parts and Cloning" Quote below...
https://www.angelfire.com/mech/beansamps/supro/supro.htm
"The original power transformers supplied to Valco were made by Triwec and carried one of these three part numbers: 330-3738, E-3738 or E-3738A.
The output transformer was also supplied by Triwec and carried four (or more) part numbers: 3778, T-3778, E-3778A and 340-3778.
Reproduction power transformers for the solid state rectified model are available from Heyboer.  Contact them and ask for a quote on part number HTS-4664.
The Heyboer transformer has a non center tapped secondary rated 325VAC @ 200mA, the filament winding is center tapped and is rated 6.3Vac @ 4A, there is no heater winding.
Magnetic Components Inc., who operates www.classictone.net  apparently is a decendant of Triwec and has started offering original spec vacuum rectified power transfomers as well as the output transformer which was used on both models. The power transformer is their part number 40-18060, and the output transformer number is 40-18061.
This power transformer has a center tapped secondary rated 700VAC @ 125mA, the filament winding is center tapped and is rated 6.3Vac @ 3.4A, the heater winding is rated 5.0Vac @ 3A."
Offline WimWalther
  • If I can't fix it I'll fix it so it can't be fixed
« Reply #11 on: January 04, 2024, 11:45:03 pm »
As already discussed in 2017
https://el34world.com/Forum/index.php?topic=22725.0
While "don't connect.." fixes the whole blowing-up issue, I'm not sure why they're bothering to use a bridge in the first place when a pair of diodes (or a tube rect, if voltages / current allow) will serve just as well.
Dump the bridge and install a pair of HFA08TB-60 HexFRED diodes, for tube rectifier sound without any of the downsides of an actual tube.
Offline bmccowan
  • Better builder than player
« Reply #12 on: January 05, 2024, 09:26:40 am »
Classictone has been gone for about 3 years. But you can still find the spec sheets on the web.
I used on to replace a 420 PT. Fortunately I did not use that schematic as a guide.
I agree that it would be good to note the errors on the schematic in the library. There are also errors on the commonly followed Thunderbolt schematic.
Mac
John Prine
« Reply #13 on: January 05, 2024, 10:53:20 am »
The problem with the H 420 schematic is the PT center tap ***AND*** the FWB are ***BOTH*** connected to ground. YOU CANNOT CONNECT BOTH TO GROUND! So, if the PT is supposed to have a CT and secondary voltage is high, you must disconnect the bridge ground or use a simple 2 diode FW rectifier. On the other hand, maybe the PT has a low voltage secondary that requires a FWB to get proper B+. It this is the case, then the PT CT should not even have a CT, and if it does, it should not connect to ground.
But we really don't know if the grounded PT CT is the drawing error, or the grounded FWB is the error. And Show Me Guitars ain't talking!
Bottom line... You cannot connect both to ground. If so, the grounded diodes will fail and may take out the PT as well.
As for the pic that Latole posted, it is taken out of context and doesn't clearly explain the note I put on it. You must read the short thread to fully understand.
« Reply #14 on: January 05, 2024, 01:37:04 pm »
Thanks everyone for the input
Offline scstill
    • Still Amp'd
« Reply #15 on: January 05, 2024, 04:01:57 pm »
Since you have this amp, could you please look at the amp and let us know if Harmony grounded the FWB or if they grounded The PT HV center tap (or even if it has a HVCT, thinking not)? Thanks.
« Reply #16 on: January 11, 2024, 02:46:40 pm »
I am happy to look but its been messed with prior to my ownership, purchased it dead and trying to revive it.
Ill post asap...
